Home › Forums › General Discussion & Questions › General Discussion & Questions › Connect passive speakers with multiroom in 2022
- This topic has 8 replies, 6 voices, and was last updated 2 years, 4 months ago by
Loshmi007.
7 June 2022 at 12:49 #35381
Heuan
BRONZE MemberWhat is currently the best way to integrate passive speakers into a B&O Multiroom system?
Now I have a BeoSound Core with several 8002 speakers. Now I want to add an additional room with passive speakers (must be outdoor).
Do I need a second Core and a BeoAmp 2 for this?
Is there any way to make it cheaper than buying these two devices that cost at least 2k€?7 June 2022 at 13:02 #35382 carolpaBRONZE MemberWhat is currently the best way to integrate passive speakers into a B&O Multiroom system? Now I have a BeoSound Core with several 8002 speakers. Now I want to add an additional room with passive speakers (must be outdoor). Do I need a second Core and a BeoAmp 2 for this? Is there any way to make it cheaper than buying these two devices that cost at least 2k€?
You can opt also for a Core or Essense mkII or BLC (Beolink Converter NL/ML) and a MCL2P of Beolink Passive as amplifier for the passive speakers.
the BLC, BL Passive, MCL2P are sold second hand regularly.
7 June 2022 at 16:25 #35383Heuan
BRONZE MemberSo theoretically i can use this configuration to accomplish an additional multiroom with passive speakers?:
BeoSound Essence MKII & MCL2P; connected via PowerLink
BeoLink Converter NL/ML & MCL2P; connected via PowerLink or MasterLink
that should both work?
7 June 2022 at 18:02 #35384 carolpaBRONZE MemberSo theoretically i can use this configuration to accomplish an additional multiroom with passive speakers?: BeoSound Essence MKII & MCL2P; connected via PowerLink or BeoLink Converter NL/ML & MCL2P; connected via PowerLink or MasterLink that should both work?
Correct; MCL2P PowerLink connected to or Essence mkII or BLC.
A BL Passive can also be used as amplifier (and a BL MCL/ML converter should also work as amp).
7 June 2022 at 19:50 #35385 MillemisBRONZE MemberEither of the 3 – MCL2P, MCL/ML Converter, Beolink Passive – will do.
They are basicly the same, when it comes to acting as an amp.Do remember that they will need a fully wired/MK3 Powerlink cable in order to turn on/of.
7 June 2022 at 22:12 #35386jvezina
GOLD MemberThe Beoamp 2 can also be used.
Just saw that it was already mentioned, sorry
10 November 2023 at 20:15 #35387Loshmi007
BRONZE MemberHi all, have similar question.
i want to connect on mu b&o shape beoamp 2 with boc 86, and then to save some costa War thinking to add beosound passive and make multiroom in bathroom also.
can someone point me in right direction is this is posibile. Can i control everything with halo.
can i reduce volume in passive, since don’t need to be so loud in bathroom 🙂
11 November 2023 at 12:29 #35388 GuyModeratorcan i reduce volume in passive, since don’t need to be so loud in bathroom
A Passive (or MCL converter) can be used with either the ML or the Powerlink input.
If a Passive is used with its Powerlink input then the volume control must be done at the source.
If a Passive is used with an ML input (i.e as part of an ML system) then you should also add an IR eye and will then be able to control its volume independently.
Furthermore, if you use an MCL2P remember that this does not have an ML input.
11 November 2023 at 19:21 #35389Loshmi007
BRONZE MemberThail you, all clear 😀
