Home › Forums › Product Discussion & Questions › BeoVision › BV6-26 – use of DVI Socket
- This topic has 28 replies, 5 voices, and was last updated 2 years, 11 months ago by
stotty1111.
14 March 2023 at 06:18 #44679
stotty1111GOLD Member(EDIT: Moved from Ouverture thread)
And another unrelated question …
I have an old BV 6-26 tv, it came out of a hotel years ago, it has limited functions, 2 scarts and essentially nothing else, I have just read the manual on here, and it indicates a DVI socket, just had a look and yes, it has, it is non operational with the limited menu facilities. I would like to use it as a pc monitor as well using the DVI.
I vaguely recall the key to access the inner memory setup features on theBV tv’s is
menu 0, 0 go,
is that correct? if not, what is it — if you are wary about using the forum, please pm me!
Thanks in advance
T
14 March 2023 at 06:57 #44680 GuyModeratorI vaguely recall the key to access the inner memory setup features on theBV tv’s is menu 0, 0 go,
Service Mode is indeed accessed by going to a SETUP menu and then pressing 0 0 GO
But the DVI socket is usually selected by simply pressing PC on the Beo4. I doubt that it has been disabled due to the previous hotel use, so I would definitely try this first.
You may have to add PC to the LIST button on the Beo4.
EDIT: As you are a GOLD member, you will be able to view the Service Manual on site – there is some useful info about service mode. Try not to muck up any settings – it is often best to take a photo of the screen before changing anything!
BV6-26 Manuals are here: https://beoworld.org/manuals_view.asp?pid=549
14 March 2023 at 19:54 #44681 stotty1111GOLD MemberYeap, thanks!
Have tried the DVI to HDMI cable to link the pc and tv , my Beo4 is one without joystick, it is prog’d with pc, pressinggo after selecting pc generates a black screen,pressing menu gives a screen for setting up the picture and volume but nothing else, then menu 0 0 go gives nothing, on the 2 x scart inputs, gives access to the 2 setup menus, but can’t find any ref to the dvi socket.
I will follow your link tomorrow, but not hopeful, i think the tv was produced to a bare minimum unit with no or few whistles and flutes!
Back to it tomorrow!
15 March 2023 at 09:56 #44682 stotty1111GOLD MemberOk, looked at the link, in actual fact i had found them yesterday!
The only sockets I have are
AV1 , AV2, IR in, masterlink, A1, A2, AV3 sound input L&R, and the 5 sockets for surround sound.
DVI socket, with connection to an HDMI socket on the pc, pressing menu gives a screen showing state of brilliance, contrast, colour, and sound , no screen showing pc output, perhaps that part of the tv programming is inactive, can it be activated? if so, how? and by me?
15 March 2023 at 09:59 #44683 stotty1111GOLD MemberThanks for splitting the topic!
15 March 2023 at 10:03 #44684 GuyModeratorThanks for splitting the topic!
No problem – it seemed sensible.
So I assume that you have selected the DVI socket by pressing PC on the remote.
I would check the PC’s hdmi output initially – you want to make sure that it will output something in a resolution compatible with the BV6 so you may have to experiment within the PC’s display settings. Also, the PC’s hdmi socket may not be active by default, so you may need to use the computer to turn it on and then decide whether it is an additional screen or a mirror of the main screen.
15 March 2023 at 10:15 #44685 GuyModeratorFurther to the above, the maximum resolution of the BV6 screen is 1280 x 768.
If you are using Windows 10, go into the computer’s ‘settings’ then ‘display’ menu, and try adjusting the ‘display resolution’ figure to match the TV. You could also use the multiple display menu (or ‘advanced display settings’ menu) to control what the PC is outputting on its hdmi socket.
EDIT: Before adjusting anything on your PC, note the current display settings so that you can restore it to the original state!
15 March 2023 at 10:56 #44686 stotty1111GOLD MemberTried various resolutions, had to use the scart input to change them them transfer lead to dvi, non worked — rapidly coming to the conclusion its programming need in the 6-26!
15 March 2023 at 11:22 #44687 stotty1111GOLD MemberThe system tells me the ideal resolution is 1024×768 convinced its the 6-26!
15 March 2023 at 11:35 #44688 GuyModeratorOk maybe have a look in the service menu. Two things to try:
– Look for a ‘BtB’ setting and see if you can turn it off. (This is the Business to Business software that the TV would have used when it was in a Hotel).
– If the above doesn’t work, you could try the TV’s ‘reset to default’ that should be in the ‘Monitor’ part of the service menu.
Also it may be worth trying another hdmi -> DVI lead – they are not all wired the same way.
15 March 2023 at 17:05 #44689 stotty1111GOLD MemberNo BtB setting on the main menu tried others, its not there!
Tried the DVI > Hdmi lead on the 7-32 works fine so that has irradicated cable probs
Reset to default the 6-26, now I cannot access the tv using pc > go on the beo4. I have reassigned the scart inputs, they both work, so confirms I think it’s a tv programming prob!
15 March 2023 at 18:18 #44690 TignumGOLD MemberHi, I do have a BC6-26(9280), and I do recall that I had to put the ‘HDCP mode’ setting to ‘hdmi’ or ‘disabled’, where ‘HDMI’ worked for my AppleTV
The menu for that is found with Be04 when the ‘cursor’ is at the ‘settings’ position in the TV menu (don’t press GO yet), then press the red arrow button, then press GO.
Go here (sorry it is in Dutch:-))
Then press ‘red arrow’, and then ‘GO’
I am not 100% sure if this is useful, as I understood that not all BV26’s have the ‘hd ready’ kit. But worth a try maybe?
Good luck, Johan
15 March 2023 at 19:31 #44691 GuyModeratorHi, I do have a BC6-26(9280), and I do recall that I had to put the ‘HDCP mode’ setting to ‘hdmi’ or ‘disabled’, where ‘HDMI’ worked for my AppleTV
I remember that too for either my BV6-26 or BC6-26, but I couldn’t find it in the Service Manual for the earlier models. Hopefully stotty can find it, otherwise I have run out of ideas other than taking the TV aspart to see if any hotel (BtB) hardware is left inside!
15 March 2023 at 19:38 #44692 stotty1111GOLD MemberThanks for that, just tried it, menu go, menu 0 0 go list , 2 items, monitor and tv tunr, tried pressing the red arrow then go, just got the normal ttv tuner list ie choice of country etc
tried again , pressing red arrow and go together , nothing
I have no idea as to the model number, no labels visible, but as previously said, it is probably 20ish years old, with an analogue tuner!
15 March 2023 at 19:55 #44693 TignumGOLD MemberHi stotty, don’t press red arrow and GO together! Please try ‘red button’, let go, then ‘GO’. 🙂
15 March 2023 at 21:55 #44694 stotty1111GOLD Membertried that first, didn’t work 🙁
Tony
16 March 2023 at 08:34 #44695 carolpaBRONZE MemberWhat signal is going out of your PC? Interlaced, as it should be for the BV6, or progressive?
16 March 2023 at 09:44 #44703 GuyModeratorTried that, without pc output and with output, the option is just test patterns the DVI is not highlighted and cannot be accessed. The Type No 9252 Item No 1816658
So that is a Mk1, whereas my BV6 was a Mk2 (Type number 9272).
I still think there may be an HDCP problem. Have a look at this old thread (you need to translate from French) about a similar type BV6-26 (type 9251) where the owner had to use an hdmi splitter to remove the HDCP. For my TV, I managed to use an hdmi audio extractor to strip the HDCP.
https://archivedforum2.beoworld.org/forums/t/27750.aspx
But of course, if even selecting the PC input is not possible (since the reset) then you are unable to try something like this.
16 March 2023 at 10:09 #44696 stotty1111GOLD MemberI wouldn’t know, we are getting into the realms of black magic here! 😉
The only observation I can make would be that I have 2x Lenovo Ideacentre Q190’s, they both work through a 7-32 with a DVI socket so i would have assumed the outputs would have worked through the 6-26. But, bear in mind it was a ‘special’ for use in a hotel. The unit did come via a B&O outlet in Chester UK! So, I would assume some prep by them was made!
16 March 2023 at 10:43 #44697 GuyModeratorMy BV6-26 was probably just as old (with an analogue tuner) and also had started life in a hotel. When using the DVI input my two problems were firstly getting the resolution right (as we have discussed), and secondly High-bandwidth Digital Content Protection (HDCP).
As far as I am aware, TV’s that are not HD-ready cannot display an hdmi signal with HDCP. You may find that you can go into your IdeaCentre’s graphics settings and turn off HDCP to see if this is the cause of the problem.
When I used an Apple TV with my BV6 I also used an audio extractor (to get the sound out of the hdmi) which had the advantage of stripping the HDCP from the signal so that the TV would display it.
I described my DVI experience in this post: https://forum.beoworld.org/forums/topic/hdmi-connection-for-beovision-7-mk1/#post-1707
