Home › Forums › General Discussion & Questions › General Discussion & Questions › B&O Radio and B&O app 7.5.1.260424517
Viewing 12 posts - 1 through 12 (of 12 total)
  • #123996
    Vedet
    Good afternoon, guys))
    The logos of radio stations in B&O Radio have disappeared in the B&O App version 7.5.1.260424517 on Android 14. This bug occurs when any radio station from any region is enabled. I contacted B&O technical support, and they replied that they could not reproduce the issue.
    I decided to ask you – if you use the stable version of the B&O app 7.5.1.260424517, please let me know if you’ve encountered a problem where the logos of radio stations are not displayed. Here are some screenshots for example. However, this issue occurs with any radio station. On the other hand, Spotify works correctly. All the images are displayed as expected. I encountered this bug after updating to the latest version.
    I would greatly appreciate your feedback to determine if this is a common issue or just my personal problem.
    #123997
    Its best to connect with B&O support in this case.
    #123998
    Vedet
    So I wrote that I contacted B&O technical support and they couldn’t reproduce the issue. I want to know if anyone else using B&O Radio in the 7.5.1.260424517 app has encountered the same problem where the radio station logos don’t display.
    Although Spotify is displayed correctly
    • This reply was modified 4 months, 1 week ago by Vedet.
    #124006
    Guy
    It won’t be much help to you, but they are working fine on Apple IOS – similar 7.5.1 … app version.
    Hopefully someone with Android can chip in!
    Vedet
    Thank you)) I would be very grateful if those answered me  those who have  Android, I have Android 14 and who do not use beta versions of updates, but the stable latest version 7.5.1.
    #124008
    Stan
    I have version 7.5.1.260424517 on Android 16, and it works fine.
    #124016
    Vedet
    Thank you, Stan)) So do you have all the logos (pictures) of radio stations in B&O Radio displayed correctly?
    #124021
    Stan
    Yes, all the logos show.
    I will try with an older phone tomorrow.
    #124025
    Vedet
    I would be extremely grateful)) Several of my friends who use Android have had the same problem.
    #124027
    Stan
    I have now tested with an older Samsung Note2o running Android 12 and the latest B&O app, and it works fine (sorry).
    #124028
    Stan
    I also just tested Mozart (Balance) vs ASE (BS2 gen1) and at first I thought I had something. With the BS2, the icon did not show in the play screen (the thumbnail showed in the browse screen), but I switched to another device and then back and then it showed.  Also, when it did not show, it did show a box with a question mark (?).  You don’t even get that. It’s like it’s not even trying.
    #124041
    Vedet
    Thank you, Stan, for your participation and your time)) It’s very valuable for me) In general, the story is strange. I sometimes have a picture on some radio stations, but most of the time I don’t. A couple of people in my region have the same problem. I have Emerge (Mozart). In your region, everything is mostly fine. It’s possible that the servers are slow and don’t load the picture for certain regions, or there’s a software error at the level of filtering traffic at the entrance to the country. But it is already clear that this is not related to wi-fi, equipment, or the smartphone, its memory, etc., as it is widespread  in your region, but in other regions, it works normally in some places and partially incorrectly in others.
    • This reply was modified 4 months ago by Vedet.
