Home › Forums › General Discussion & Questions › General Discussion & Questions › B&O Beocord VX7000 Compatibility with a Beovision LX4500 TV
  • #125855
    ryan.nicholson93
    Struggling to find a definite answer on this so hopefully someone on the most knowledgeable B&O forum can help me.
    Will a BeoCord VX7000 work properly with my BeoVision LX4500 TV, particularly when it comes to remote control operation?
    I’ve heard mixed things online, so I’m hoping someone can clear this up.
    I have both a Beo4 and a Beolink 1000 remote. From what I’ve read, some later VX7000s apparently only work with the Beo4, which seems quite unusual for B&O. I’m not sure whether that information is actually correct, as pretty much every bit of B&O kit I own from around the same period works perfectly fine with either remote, apart from my Beosystem 5000.
    What confuses me even more is that the much later V8000 VCR and even the DVD-1 are known to work perfectly fine with the LX4500, including remote control operation.
    So why is there such a grey area surrounding the VX7000’s compatibility? Especially considering it was released only about a year after the LX4500 was discontinued.
    Has anyone actually used a VX7000 with an LX4500 and can confirm whether everything works as it should, including play, stop, rewind and fast forward using the TV’s remote?
    Picture below of the current setup
    Favourite Product: Beomaster 6000 Quad
    Guy
    Have a look at this thread – I see no reason to doubt Peter’s answer about specific type numbers:
    https://archivedforum.beoworld.org/forums/p/30070/239141.aspx#239141
    solderon29
    GOLD Member
    As other’s have stated,the machine will function,but may exhibit odd behavior depending upon the level of software on board.
    B&O continually updated the software to include new functions and to ensure compatibility with newer product,but of course not alway’s backwards compatibilty.
    The earlier VX5500 should be a plug n go solution.
    I have a spare one up for grab’s,which was functioning before storage.Free to you for shipping costs,or collect if local-ish?
    Warwick.U.K.
    Nick
    #126071
    pl212
    SILVER Member
    Agree Peter’s post is the right info on this.
    To test out my web port of the Product Configuration Guide, I got this response from the 1997 Great Britain Rulebook:
    ************************* VIDEO SYSTEM SETUP **************************
    Beovision L 4500
    Beocord VX 7000 (VTR 1)
    Connection Video
    Connect the VTR 1 to the AV 1 socket of the TV-set using a fully
    specified 21/21-pin A/V cable (RGB cable).
    Connect the aerial to the aerial input of the VTR 1.
    Connect the aerial output of the VTR 1 to the aerial input of the
    TV-set using a coaxial cable.
    Selecting option on the TV-set
    Option:  OPTION 1.5 (Factory setting)
    Press:   STANDBY  PICTURE 1 STORE
                      PICTURE 5 STORE
    Programming the setup
    VTR Setup: VX 7000 type 461x
    Press:  V.TAPE MENU 0 0 PLAY
    Select   "SW-version" med PLAY
    Press:  TURN (BL1000 MK1/MK2)
            SHIFT PICTURE (BL1000 MK3/MK4)
            MMI 1: is for Beolink 1000
            MMI 2: is for Beo4   (factory setting)
    Press:  STANDBY and cut the mains supply to the VTR for 10 sec.
            After connection to the mains supply the VTR will function
            with the remote control selected.
    Note!
    All products must be interconnected before they are connected to
    the mains
    The Beovision must be equipped with software (S/W) 2.1 or
    higher, part No. 8341713.
    The VTR cannot playback the sound of NTSC tapes in stereo.
    If the VTR modulator frequency interferes with other signals in the
    UHF range, adjust the modulator frequency by means of the screw
    on the rear panel of the VTR.
    The recommended distance between channels in the UHF range is
    16 MHz.
    ********************* REMOTE CONTROL FOR MAIN ROOM ********************
    The recommended remote control is Beolink 1000
    The following remote controls may also be used:
    Beolink 7000 (2-way IR setup for the A/V system)
    Beolink 5000 (2-way IR setup for the A/V system)
    • This reply was modified 1 week, 3 days ago by pl212.
