Home › Forums › Product Discussion & Questions › BeoVox › Beovox MS150 re-foam surround on woofer and subwoofer
- This topic has 1 reply, 2 voices, and was last updated 3 years, 3 months ago by
AdamS.
20 November 2022 at 07:53 #40915
RendboellGOLD MemberHi Beoworld,
I need help with a pair of Beovox MS150 that need re-foam of the woofers and subwoofers.
I have the service manual with a technical drawing of the parts, but there is no instruction on disassembly.
I have pulled the woofers and subwoofers out of the cabinet, but how do you remove / disassemble the plastic rings / frames on top of the units?
Are they glued to the baskets or just sort of clicked in place?
I do not see any taps to pull to remove the frames.
Best regards,
Jens
Favourite Product: Beomaster 7000
Signature: Jens Rendboell
21 November 2022 at 14:28 #40916 AdamSBRONZE MemberThey are just an interference fit. Once the drivers are out, give them a tug or a gentle tap with a hammer and they’ll pop off.
