Home › Forums › Product Discussion & Questions › BeoVision › Beovision Horizon
- This topic has 6 replies, 4 voices, and was last updated 3 years, 8 months ago by
Ckbrookes.
23 July 2022 at 12:32 #36305
Ckbrookes
BRONZE MemberI have just taken my Beovision out of storage but the beoremote one is lost, also I have just the green light with no picture ?
two questions can I use any BO remote and should I not have some sort of picture when plugged in
thanks in advance
col
23 July 2022 at 17:13 #36306 Hiort
GOLD MemberTo my knowledge you can only use the Beoremote One with the Horizon.
Not sure why you only get green light. I assume it would go into standby when you plug it to the mains.
23 July 2022 at 17:56 #36307Ckbrookes
BRONZE Memberhi
much appreciated, the green light only
stays on for one minute and then goes blank
ill have to find another beoremote one
kind regards
col
23 July 2022 at 18:10 #36308 GuyModeratorI may be wrong but is it possible to control it with the Bang and Olufsen app (which replaced the Beoremote app)? The TV would have to be connected to be connected to the same network as the phone, so this will only work if the TV is able to connect based on its previous settings. It could be worth connecting the TV directly to your router with a network cable, and then see if the B&O app can find and control it.
It’s just a thought – I don’t have such a modern B&O TV ?
23 July 2022 at 18:11 #36309 MillemisBRONZE MemberBe sure to get the Beoremote One/BT.
The BV Horizon only works with bluetooth!
Tip!
If you have the Bang & Olufsen app and the tv is online/on the same network as the device with the app, you can control the Horizon that way.MM
23 July 2022 at 18:12 #36310 MillemisBRONZE MemberWell….Guy was faster than I ?
23 July 2022 at 18:57 #36311Ckbrookes
BRONZE MemberThanks all
for your help the BOApp worked ,
but only to show me a crack LED Must of happened in storage!!
is it worth getting a new screen?
much appreciated
col
