Home › Forums › Product Discussion & Questions › BeoVision › Beovision Horizon
- This topic has 9 replies, 7 voices, and was last updated 8 months ago by
Jesper Godsk Nielsen.
24 May 2022 at 06:36 #35004
Ckbrookes
BRONZE MemberHi all
has anyone had a cracked screen replaced on a 48 Horizon tv
regards
Col
26 May 2022 at 10:31 #35005tigermann5000
BRONZE MemberYes I already had such a case.
30 July 2022 at 16:38 #35006Ckbrookes
BRONZE MemberHi All
another question for the experts, what make of screen has the Beovision horizon 40 have, I’m going to attempt replacement my self ?
kind regards
col
31 July 2022 at 10:34 #35007 GuyModeratorI would hazard a guess at Samsung, but your best bet is to take the TV apart and look for a label!
2 August 2022 at 16:05 #35008 HiortGOLD MemberIts a Samsung panel inside Horizon.
27 September 2023 at 01:38 #35009Pipeandslippers
BRONZE MemberIt is a Samsung LTA480FJ02.
See here for more info: https://www.panelook.com/LTA480HJ02_Samsung_48_LCM_overview_23500.html
Did you have any luck with it?
27 September 2023 at 09:56 #35010Ckbrookes
BRONZE MemberHi
Is that for Beovision 11 55 ?
I haven’t done anything with it as yet because I wasn’t sure if it was the engine or the screen, I have fant coloured vertical lines that don’t always show up, only on certain backgrounds,
kind regards
col
27 September 2023 at 11:39 #35011Pipeandslippers
BRONZE MemberNo that’s a Beovision Horizon 48 panel.
9 June 2025 at 20:19 #66266Yemi Lawal
BRONZE MemberHi
I just cracked my Beovision 48 horizon lcd panel as well. Going to unscrew back to get label details. Is it easy to replace lcd screen?
10 August 2025 at 15:51 #68708Jesper Godsk Nielsen
BRONZE MemberThe panel in my Horizon 48″ is also broken.
I’m looking for a new panel, does anyone know if they can still be obtained?
Favourite Product: Beomaster 7000, Beovision 11 - 40"
