Home › Forums › Product Discussion & Questions › BeoVision › Beovision 10-32 ‘Boot-Up’ time over masterlink
- This topic has 6 replies, 4 voices, and was last updated 3 years, 9 months ago by
Guy.
8 June 2022 at 10:17 #35396
GuyModeratorWhilst temporarily living in a rental property, the only piece of B&O equipment that I am currently using is my Beovision 10-32 in the living room. It is fitted with the DVB-HD (T2C) module, and the boot-up time (from pressing ‘TV’ to a picture appearing) is just over 30 seconds.
Whilst I can live with this delay for TV (there is little that I am in a rush to see!), I also use the TV for radio. I currently do this via the Freeview radio channels – eg channel 704 for BBC Radio 4. Of course these take just as long to ‘boot-up’ as TV programmes, which I find frustrating.
My question is this: If I connected a B&O audiomaster (eg BS3000) to the BV10-32 by masterlink, making use of the TV’s speakers, would pressing ‘RADIO’ on the remote result in an instant response – i.e radio audio without the ‘boot up’ delay? Or does the TV still need to go through the 30-second ‘boot-up’ process to play masterlinked audio?
8 June 2022 at 14:02 #35397 Keith SaundersBRONZE MemberThe short answer is it will take the same length of time.
The long answer is whilst the TV does have a boot up time, the main delay is the Masterlink power on sequence even if you don’t have something connected to the Masterlink.
8 June 2022 at 17:11 #35398 GuyModeratorThanks Keith – that’s very useful to know. I think that I’ll look for another solution, perhaps add a Beosound 1 (original version) to my collection!
13 June 2022 at 13:10 #35399 stefanBRONZE MemberWhilst temporarily living in a rental property, the only piece of B&O equipment that I am currently using is my Beovision 10-32 in the living room. It is fitted with the DVB-HD (T2C) module, and the boot-up time (from pressing ‘TV’ to a picture appearing) is just over 30 seconds. Whilst I can live with this delay for TV (there is little that I am in a rush to see!), I also use the TV for radio. I currently do this via the Freeview radio channels – eg channel 704 for BBC Radio 4. Of course these take just as long to ‘boot-up’ as TV programmes, which I find frustrating. My question is this: If I connected a B&O audiomaster (eg BS3000) to the BV10-32 by masterlink, making use of the TV’s speakers, would pressing ‘RADIO’ on the remote result in an instant response – i.e radio audio without the ‘boot up’ delay? Or does the TV still need to go through the 30-second ‘boot-up’ process to play masterlinked audio?
Boot up time on my BV10-32 for RADIO (from BS9000 over ML – BS9000 A.OPT 0 in mainroom and BV10-32 in V.OPT 6 in linkroom) is 7 seconds.
Boot up time BV10-32 for direct TV (with an old PUC connected HD Dreambox, Sat receiver) is 17 seconds.
Boot up time on my BV7-40 with built in Beo HD Satreceiver is 38 sec. – with Dreambox on the same BV 17 sec.
Hope this helps
Stefan
13 June 2022 at 13:25 #35400 GuyModeratorBoot up time on my BV10-32 for RADIO (from BS9000 over ML – BS9000 A.OPT 0 in mainroom and BV10-32 in V.OPT 6 in linkroom) is 7 seconds. Boot up time BV10-32 for direct TV (with an old PUC connected HD Dreambox, Sat receiver) is 17 seconds. Boot up time on my BV7-40 with built in Beo HD Satreceiver is 38 sec. – with Dreambox on the same BV 17 sec. Hope this helps Stefan
Thanks for that stefan – very useful to know! 7 seconds is not too bad at all.
However, I decided to go an alternative route and got hold of a BeoSound 1 (with FM radio and CD) to solve my ‘instant’ radio requirement. It’s more than adequate for the current living room.
Prior to getting the BeoSound I was going to do some experimenting with ML cable, a BeoLink1611 and my BeoCenter 2300, but my B&O collection is currently in these boxes which aren’t labelled too well. I suspect the 1611 converter is in the box in the far corner! Far easier to buy something new!
PS: Since that photo was taken there are more (non-B&O) boxes on top and alongside!
13 June 2022 at 18:24 #35401 matadorModeratormy B&O collection is currently in these boxes…
Looking forward plenty of “unboxing” vids! 🙂
14 June 2022 at 09:17 #35402 GuyModeratorLooking forward plenty of “unboxing” vids!
Some of the stuff has been in boxes for 12 years (and 6 house moves!), so it will indeed be exciting to find out what’s there. When UK house prices plummet ‘?’ and I can afford to buy my ‘forever house’, I look forward to getting everything out and working out where to put it. ?
