Home › Forums › Product Discussion & Questions › BeoTime › Beotime not working
- This topic has 2 replies, 2 voices, and was last updated 3 years, 11 months ago by
mdonald.
8 April 2022 at 03:51 #34010
mdonald
SILVER MemberHi all,
I Am Michele, a month ago I bought a BeoTime, the flute, or the Magic wand, the seller told me it did’t work, but for all this period it worked well.
Now without a precise rule, it switches off completely, and it is enough to remove the batteries and put them back and it starts again.
I would like to try to fix it.
Some time ago I saw on the forum that someone had worked on it, and perhaps there was the possibility of having the service manual from the site, with a silver or gold subscription, but now I cannot find the topic, perhaps with the change of forum, I can not find it
Thanks in advance for any help you can give me.
M
8 April 2022 at 05:17 #34011 GuyModeratorHi and welcome to Beoworld!
The Service Manual is indeed available on the Main Web Site ‘Products’ link (site for Gold and Silver Members) here: https://beoworld.org/manuals_view.asp?pid=1275
The fault finding in the service manual is limited to: No display; No sound:; and no IR transmission, but it should help you dismantle (carefully!)
I think I remember the thread that you mentioned but it is most likely on the previous forum that we can’t currently access. It’ll be back eventually I am sure.
I wouldn’t want to take a Beotime apart without further advice/photos!
14 April 2022 at 09:21 #34012mdonald
SILVER MemberThank you for your replay.
I will wait for the old forum, now the beotime seems to work, maybe the battery pack rotate in the body and loose the connection. I am trying to manage it very softly.
thank you again.
Michele
