Home › Forums › Product Discussion & Questions › BeoSystem › BeoSystem 4 Auxiliary In
- This topic has 6 replies, 4 voices, and was last updated 3 years, 8 months ago by
Mark.
14 July 2022 at 06:56 #36149
Mark
BRONZE MemberI finally found a Beogram 8002 in good working condition! I have a Soundsmith cartridge and phono preamp. I would like to connect this to the auxilary in on my BeoSystem 4 and I was wondering if B&O has a RCA to BeoSystem 4 Din cable in about a meter length.?
14 July 2022 at 19:22 #36150 MillemisBRONZE MemberThey do – or at least they did.
I use one myself (which is longer).However, you will have to ask a dealer, if he still can order it.
Maybe Steve@SoundsHeavenly knows more.
15 July 2022 at 02:05 #36151Mark
BRONZE MemberThanks MM.
I’ve contacted my dealer and haven’t heard back from them yet. I’ll keep my fingers crossed that they still have it available. It’s definately not their standard DIN!
I am very pleased with this 8002 as it has been refurbished and seems to work very well. This will be my second 8002 from eBay. The first was nothing but trouble, and the old B&O repair shop around here (when we had B&O dealers) had it several times for different issues and the fix never lasted! Probably needs a capacitor overhaul.
It’s nice to have a record player again!
15 July 2022 at 09:25 #36152beoandy
BRONZE Memberhi! it´s a mini din 9-pin on the beosystem 4
beoandy
15 July 2022 at 18:47 #36153Mark
BRONZE MemberThanks Beoandy!
That actually helps! If I can’t get a cable from my dealer maybe I can get one made. It looks like the mini 9-pin dins to make your own cable are a bit hard to find.
16 July 2022 at 09:30 #36154 GuyModeratorI have not used this supplier but here’s a cable: https://www.ebay.co.uk/itm/134055567663
Add one of these for RCA: https://www.ebay.co.uk/itm/123024786244
Otherwise I am pretty sure that B&O supply a mini 9-pin to SCART plug/socket – see the following details (with part numbers) from the Beolink Handbook (click image for larger picture):
Then if needed your could stick one of these on the end of the SCART: https://www.ebay.co.uk/itm/333261656955
16 July 2022 at 17:41 #36155Mark
BRONZE MemberI’ll keep these options in mind. My first preference is to use the minimum number of cables needed, but if I can’t find a stereo RCA to 9-pin mini din cable then I may have to go this route.
