Home › Forums › Product Discussion & Questions › BeoSystem › Beosystem 2500 powerlink failure
- This topic has 10 replies, 4 voices, and was last updated 3 years, 4 months ago by
matador.
18 November 2022 at 05:41 #40885
pepps
ModeratorHello,
My beloved Beosystem 2500 has suddenly stopped outputing via Powerlink.
I had it connected to a BL converter and was playing through some Beovox, working fine.
However today I took delivery of a fab pair of BL2500s but they won’t play.Red lights on Beolabs come on.
Red light on Beosystem comes on.
Beosystem plays cds, radio, tape – but Beolabs don’t click on to green and remain silent on red.I connected the Beolabs up to a Beovision in the kitchen and sure enough they go green and play sound.
I’m baffled.
I connected a pair of Beolab 6000 to the Beosystem 2500 with a Powerlink mk3 cable and it won’t activate them either.
Do Powerlink sockets “go off”? Do they die?
Can anyone think what might be the reason why the sockets no longer seem to work?Location: Kent, UK
Favourite Product: Beosystem 6500
19 November 2022 at 09:15 #40886Die_Bogener
BRONZE MemberPress “Mute” in Standby on the keyboard… and a light will go on.
A converter deactivates the Powerlink.
19 November 2022 at 11:09 #40887 pepps
ModeratorHi there,
Thank you for replying.
Activating and deactivating the mute as you kindly describe doesn’t have any effect on switching on the Beolabs sadly.
Any other ideas?Location: Kent, UK
19 November 2022 at 11:20 #40888 GuyModeratorWhen you say that you ‘had it connected to a BL converter and was playing through some Beovox’, do you mean that you were using an ML/MCL converter as a Passive (amplifier) using its PL input, and were you connecting it to the BC2500 using the same PL Mk3 cable that you are trying to use with the Beolabs?
19 November 2022 at 11:27 #40889 matador
ModeratorHi, I’m not good at this but what comes to my mind:
Do you have sound from the headphone socket?
Did you deactivate the converter as mentioned above?
Do the mute light light on or off accordingly, meaning could it be a stuck key on the keyboard?
Could it be the headphone switch that is stuck?Location: Paris France
19 November 2022 at 11:41 #40890 pepps
Hi Guy,
Thanks for your reply. I was using a Powerlink cable I bought from Steve at Soundsheavenly from one of the Powerlink sockets on the BC to a MCL2P and then on to the Beovox.
I’ve since tested the BL2500s with my BV6 using both a Mk3 Powerlink cable (works fine) and the original 5-pin Powerlink cables which came with the BL2500s (works fine).
Julian
19 November 2022 at 11:45 #40891 pepps
ModeratorHi, I’m not good at this but what comes to my mind: Do you have sound from the headphone socket? Did you deactivate the converter as mentioned above? Do the mute light light on or off accordingly, meaning could it be a stuck key on the keyboard? Could it be the headphone switch that is stuck?
Hi Matador,
Um no, I didn’t deactivate the converter. It was an MCL2P – I didn’t state that correctly in my original post sorry.
The mute button on the keyboard does activate the little green light as expected. Doesn’t appear to be stuck.I’ve connected headphones and sound plays through them fine. I don’t hear a relay click when I plug them in though.
Perhaps a randomly failed headphone relay?Julian
19 November 2022 at 12:07 #40892 pepps
ModeratorSOLVED!
After your useful comments and suggestions I have solved the problem (for now).
I tried the old classic ‘plug in and unplug repeatedly’ a headphone connector in the little headphone socket.
And sure enough it all sprang into life!I love this forum! Always helps get results when we work together!
Thank you all!
19 November 2022 at 12:12 #40893 matador
ModeratorThat’s weird! If you’ve been using the converter through a Powerlink wire and the converter cliks in/cliks out, it means the powerlink socket is correctly passing sound and power (right now I’m wondering if there is the same pin that triggers both devices beolab or converter…).
As for the headphone socket, I dont know if it’s a relay or just a switch built-in the jack socket. When I tried it just before posting, I didnt hear any relay appart from the loud ones from the beolabs just there.
19 November 2022 at 12:22 #40894 GuyModeratorAs for the headphone socket, I dont know if it’s a relay or just a switch built-in the jack socket.
I was just looking at that as the thread updated. According to the service manual the headphone socket has a physical switch that connects PL pins 4 to ground – there is no relay.
Great news that it’s all working Julian – enjoy your new speakers! ?
EDIT: And I think that the MCL2P uses Powerlink pin 1 to trigger, not 4. This would also explain why I could never use my BC2300 Mute button to mute the speakers when I had an MCL2P as an amplifier.
19 November 2022 at 12:51 #40895 matador
ModeratorI tried the old classic ‘plug in and unplug repeatedly’ a headphone connector in the little headphone socket.
Great, congratulations,
Maybe (but would be good to wait for the approval of somebody that knows about that…) you could unplug the whole unit and spray contact cleaner into the jack?
