Home Forums General Discussion & Questions General Discussion & Questions Beosound Ouverture – no output to powerlinks
Viewing 8 posts - 1 through 8 (of 8 total)
  • #61727
    OldJack
    As of last week,my Ouverture stopped to  activate powerlinked beolabs 4000(red lights on beolabs do not turn to green)on all sources.Otherwise,all functions working properly.
    Temporarily,I am using headphones output cable from Ouverture to rca line-in to beolabs,and speakers are functioning normally.
    Any idea if/how to solve this?
    #61732
    Guy
    It’s not simply muted is it?  As far as I know, the MUTE button just mutes the PL outputs and not the headphone socket, which has separate volume control when PL is muted.
    Otherwise, any results from repeatedly pressing mute whilst speakers are connected? (and headphones disconnected)
    One further suggestion:  In case the headphone socket has any muting function, try repeated insertion/removal of headphone plug (and possibly clean internal headphone contacts).
    OldJack
    Thanks,Guy, I tried everything.On powerlinks,beolabs are not activated.Won’t turn green,remaining on red lights,on any audio source from Ouverture.On line-in inputs all functioning as it should.
    #61954
    billb
    GOLD Member
    I would check the 3V battery to see if it has leaked and etched the board beneath it.  I had a BS3000 with the same symptoms and it turned out that the battery had leaked and the acid etched the traces.  The battery is on PCB 3 (Microcomputer).
    Bill
    #61962
    Guy
    Good point from Bill above!  For info, here’s some pictures showing the battery location in a very similar layout BC2300 – you have to remove the metal cover to access:
    IMG_7955
    IMG_7956
    pepps
    Hi, here’s further reference to the headphone socket and it’s relation to powerlink.
    https://forum.beoworld.org/forums/topic/beosystem-2500-powerlink-failure/#post-40885
    Favourite Product: Beosystem 6500
    marexy
    SILVER Member
    Try to mesure 4 to 5V on trigger pin on PL connector. At some point can be power supply issue. Or plug in plug out heaphone jack…than we can go on😎
    #62355
    OldJack
    On both powerlink outputs no power(reading zero).As I am not skilled,will send it for repairs.
