Home Forums Product Discussion & Questions BeoSound beosound moment
Viewing 19 posts - 1 through 19 (of 19 total)
  • #45089
    ejmbon
    hi all new here im justabout to buy a beosound moment.. what i want to know is was it a good decision or not
    thanks ejmbon
    #45090
    Hiort
    Think you can find a lot of opinions about Moment in the forum.
    I think its important for you to think about what is your main use case.
    I owned one a number of years and liked it a lot.
    However, today it is an unsupported product so some initial features does not work like the “mood wheel”, since that rely on integration to Gracenote metadata that does not exist any more.
    Also, I have seen some people having the tablet screen failing.
    So, let us know why you are thinking of being one to make it easier to provide advise.
    #45091
    bnousr
    Congratualation to what I would say a nice buy and enjoy the system and yes, there are still a lot of opinions on the system.
    As said, depends on your expectation, but I’ve had the Moment now more or less since it was released and use it almost every day for either playing TuneIn (Net.Radio) or Music (Net.Music) and it has served well. As @Hjort indicate, some features has been lost over time, such as the “mood wheel” function which was depaded a lot already when it was released were I kind of liked the MOTS function more. Also, going back, initially I really wanted the Beesound 5 but at that point in time didn’t have any idea how to hide away the main box, and when the Moment was released my wife bought the unit. But, if you’re into having it to be able to play both Deezer and DLNA-source, then it works very well. Overall happy customer with the Moment in general, just pitty that the support was dropped just after a few years. Also, from design, not really on the same level as some of the older system, such as Beosound 5 which I still think is the best looking digital audio system on the market (and if B&O would reluanch an updated version I’ll buy it in a blink).
    #45092
    ejmbon
    thanks all im just using it on tune in at the mo.with only one icon
    showing fully. dont know what happened to the rest
    ejmbon
    #45093
    bnousr
    What does your list on TuneIn show? The list of the stations that you defined on TuneIn should show up proper with icons and in the order you’ve defined it. Might be that the ones that doesn’t show up (and do they play?) might be free account limitation with TuneIn. Don’t recognise this and I very seldom login to TuneIn; I mean I’ve been using the same list of channels since I got my Moment which mirrored my ‘standard’ FM channels ๐Ÿ™‚
    #45094
    ejmbon
    Thanks for the reply. all the tune in favs work but not only one icon showing
    I dont know how to mirror my fav fm channels as tune in has no bbc channels
    and on setup it only shows tune in for radio. i might try tune in premium to see
    if that works thanks ejmbon
    #45095
    bnousr
    I’m located in Sweden and if I check via my free TuneIn account it shows quite a few BBC stations:
    tunein_bbc
    #45096
    ejmbon
    HI all my beosound moment has developed a fault it keeps looping
    the logo nothing else can i somehow reset the tablet, i tried the 4 button press on wheel
    no joythumbnail_IMG_0451thumbnail_IMG_0452
    #45097
    bnousr
    To make a proper shutdown of the Moment, do the following:
    1. Shutdown the Moment Hub (SoundHeart) fully by powering it off.
    2. Remove the BeoSound Moment interface (Jukebox) from the BeoSound Moment hub (SoundHeart) so it is not in charging position. Press and hold a thin pointy device (e.g. a paper clip) into the pin-hole for 2 seconds and let go. This will shutdown (Power Off) the BeoSound Moment interface (Jukebox).
    Moment_SoundHeart
    3. If less than 1 second no action will take place. (If more than 5 seconds the aluminium touch wheel and the wood touch wheel will loose function; to continue from this situation, place the BeoSound Moment interface (Jukebox) for charging in the BeoSound Moment hub (SoundHeart) and redo all the above instruction steps).
    4. Wait 4 seconds.
    5. Place BeoSound Moment interface (Jukebox) for charging on the BeoSound Moment hub (SoundHeart) by which the BeoSound Moment interface
    (Jukebox) will wake-up.
    6. Power on the Hub and you’ll should hopefully see that both units now boots up as it should.
    #45098
    ejmbon
    thanks for that, but still no joy ejmbon
    #45099
    bnousr
    What about the LED on the back on the Hub, does they indication any issues? Here is the LED indication chart from the installation guide:
    Moment_LED_Indications
    Also, are you the Hub using wireless or wired network and are you able to see both units on your local network if you scan your network for devices (you can use tools such as Advanced IP Scanner for Windows)? Additionally, since the Moment Jukebox make use of wireless network (2.4 GHz); any issues with signal strenght were the Moment is located?
    #45100
    ejmbon
    this is a video of it
    #45101
    Carolpa
    leave the Moment Hub off the Soundheart until it’s battery is drained completely.
    put the Hub back on the Soundheart and follow bnousr 6 steps.
    edited:
    wait some time to let the battery recharge a bit.
    reset the the Hub (see above) with a pin/paperclip.
    #45102
    ejmbon
    Hi all guess what i bought another moment and have a question to ask.
    Can i connect my new sonos era speaker to the moment as i tried the search
    on the moment without any joy
    thanks Ejmbon
    #45103
    Millemis
    GOLD Member
    Hi all guess what i bought another moment and have a question to ask. Can i connect my new sonos era speaker to the moment as i tried the search on the moment without any joy thanks Ejmbon
    The Era has a line-in connection – see here:
    Sonos Era line-in how-to
    From the Moment/Powerlink out, you will need an adapter cable to connect to the Era/line-in dongle.
    However, please allow me to askโ€ฆ.what a you trying to achieve with this combination, that the Era can not do on its own with the Sonos app?
    Maybe you are using the beolink to other B&O devices function???
    #45104
    ejmbon
    Thanks all now running moment on beolab 4 sounds great. tried connecting my m3
    no joy, but im happy now thanks everyone.
    ejmbon
    #61415
    paul_mcbride
    Hello,
    I am able to play custom TuneIn streams on my Moment as long as they are .m3u format. ย The m3u8 streams donโ€™t play and so Iโ€™m wondering how you get radio.net streams to work through TuneIn on the Moment? Specifically I am looking to play the BBC radio 1-4 streams all of which end in .m3u8 as fas as I can see/find.
    Thanks for any insight here.
    Paul McBride
    #64967
    CharlieWednesday
    GOLD Member
    Hi
    Reinvigorating this thread as I’ve just bought a Moment myself, and would like some advice on it.ย  I currenty use a Beosound Essence Mk2 for digital music, but the Moment appealed to me due to its dedicated screen, and it does look good too.ย  I managed to get one for ยฃ200 (from a B&O dealer too), so it seemed a real bargain.
    I know that the functionality is more limited now but I don’t seem to be able to get much on it at all.ย  I have not yet connected my NAS drive for DLNA music but I’m sure that will work.ย  What I’m having trouble with to begin with is TuneIn and Deezer.
    TuneIn: I signed up for a free TuneIn account to try it, and I was able to add the account to the Moment, but then I see nothing – if I swipe to the Radio screen, it just says ‘Radio’ at the top, and no stations are displayed.ย  I added some favourite stations to my TuneIn account on my PC, but I still see nothing on the Moment.
    Deezer:ย  I signed up for a free Deezer account to try it (I’ve always used Spotify premium before, but would be happy to move to Deezer if it works), and I can log into it on my PC and phone, but if I try to log into it on my Moment, it fails each time.ย  I’m assuming this should still be working on the Moment – still supported?
    Could it be that the Moment will only work with premium accounts on both TuneIn and Deezer?ย  I’d be happy to get premium accounts on both, but would want to be certain they’ll work on the Moment first.
    Also I’ve read that it’s possible to get Spotify Connect on the Moment by going into the service menu and sideloading it in the android backend – does anyone know any more on how to do that?
    One thing that has worked okay is streaming to it via Bluetooth – so at least I’ve been able to get it to play something!
    My B&O Icons: No description available No description available No description available No description available No description available No description available No description available
    #64986
    CharlieWednesday
    GOLD Member
    I have been experimenting with the Moment sand I’ve figured some stuff out.ย  For Deezer, a premium subscription is required, so I got one, and now that works fine.
    For TuneIn, a premium subscription may also be required, but I’m not going to bother with that now.ย  I only really listen to BBC Radio stations (in particular, 6 Music) and they are not available in the UK via TuneIn, because the BBC would prefer UK users to use their own BBC Sounds app.ย  Good for the BBC, but not good for the Moment.
    If I want to listen to BBC Radio, I’ll just stream to the Moment via Bluetooth from my phone or tablet.
    The Spotify question remains though – if anyone knows how to get Spotify Connect on the Moment, I’d be very grateful for the knowledge.
