Home › Forums › Product Discussion & Questions › BeoSound › Beosound 9000 Option setting.
- This topic has 12 replies, 4 voices, and was last updated 11 months, 3 weeks ago by
matador.
12 December 2024 at 14:25 #61532
matador
ModeratorHi alls,
I know this must have been discussed somewhere but all my search came back useless.
I have an 9000 connected via aux.out to a Playmaker.
I’d like the playmaker repond to usual IR commands and the 9000 – which I use less – respond to Link commands (to my understanding press “Link” + “CD” etc…).
First, I dont know which option is that.
Second, The IR option setting desnt seems to work (no blinking led on the 9000). Dummy Beolab plug is on.
Thanks for the help.
12 December 2024 at 15:14 #61535 GuyModeratorFirst, I dont know which option is that.
A.OPT 4 for the BS9000.
But I am not sure why the option setting wouldn’t work! Dummy plug continuity?
EDIT: But maybe early SW versions of BS9000 don’t accept A.OPT 4.
12 December 2024 at 16:56 #61541 matador
ModeratorHi Guy.
SW 2.0.
A.Option setting to 4 does not work : 1,2 & 5 or 6 do work.
I’ve always wonder how those kind of detail could be relavnt for anyone. Now I know!
Thanks Guy.
12 December 2024 at 17:31 #61542 matador
ModeratorWell.
Here is the setup:
Playmaker. Receiving Airplay broadcast and BS9000 into Aux.in.
Playmaker must be the main IR controlled device because my phone keeps corrupting airplay reception and also because autosense don’t work that well.
But then A.Aux or any audio command like CD to select the line IN of the PM also select that source on the 9000 making impossible to select Line IN in the PM and CD on the 9000.
So in short, I’d like to be able to select independently PM Line.IN, PM Airplay, BS Sources at least CD and AUX.*
An Idea Somebody?
Thanks in advance.
*Because 75% of the time music is Airplay, I’d rather not to have the PM as a slave for the BS Implying that tha BS has to be on everytime.
12 December 2024 at 18:01 #61544 GuyModeratorMaybe put the Playmaker in A.OPT 4 and use a second Beo4 remote in permanent LINK mode. Far from ideal, but I am struggling to think of another solution!
13 December 2024 at 10:13 #61550 matador
ModeratorWhen in A.Opt 4, does all command need “Link” pressed before or do some commands like Volume and Mute work as usual?
13 December 2024 at 10:48 #61551 GuyModeratorWhen in A.Opt 4, does all command need “Link” pressed before or do some commands like Volume and Mute work as usual?
All commands will need LINK first.
A thought: You could perhaps connect a Beolink Active by ML to the BS9000 (in the same room). Speakers also connected to Active.
BS9000 in A.OPT 0.
BL Active in L.OPT 4.
And the PM could be connected either to the BS9000 AUX (LINK then A.AUX), or to the Active’s PC input as a local source (L-PC).
13 December 2024 at 16:07 #61571Madskp
GOLD MemberWhen in A.Opt 4, does all command need “Link” pressed before or do some commands like Volume and Mute work as usual?
All commands will need LINK first. A thought: You could perhaps connect a Beolink Active by ML to the BS9000 (in the same room). Speakers also connected to Active. BS9000 in A.OPT 0. BL Active in L.OPT 4. And the PM could be connected either to the BS9000 AUX (LINK then A.AUX), or to the Active’s PC input as a local source (L-PC).
A very good idea to get opt. 4 to products that do nat have that 🙂
But in order for Matador to get the functionality requested I think it would be better to use the L and R out in the PC connector of the 1636 (see this thread for pinout https://forum.beoworld.org/forums/topic/beolink-active-1636-pc-input/#post-43100 ) to connect to the line in of the Playmaker. Hope this makes sense
13 December 2024 at 16:11 #61572Madskp
GOLD MemberA very good idea to get opt. 4 to products that do nat have that 🙂
And also a very good way to utilise some black boxes 😉
13 December 2024 at 17:59 #61577 matador
ModeratorThank you to the Men In Black Boxes Team!
I’d like to not add another box to the setup. It already has a Beolink passive that drives Beovox C-40 in the back from the Playmaker Powerlink out.
The less bad option would have been using a Beo4 to command the 9000 and the Playmaker in Option 4, not the more convenient but at least just one remote.
The problem is that I dont use Beo4, I use a Beolink 5000 I find nicer.Another solution would be a fine programming of a Beo6 but I keep that for later.
Thanks again to you both.
19 December 2024 at 18:35 #61757 matador
ModeratorThen this how it ends so far…
I specify I’m using a Beolink 5000.
BS9000 in A.Opt1 (IR control enabled).
Playmaker in A.Opt4 (needs “Link” button prefix).Pros:
Full IR control on the 9000 allowing to control CD and select sources like radio (I’ve discover the very fancy RDS display with song names, etc…), but also and most important, “Phono” that allows me to open the path to the BG4002 and enjoying the “Phono” display…Allows me to get rid of the external source selector I used to use to switch the line in from the Playmaker between BG and BS.
The “+link” gymnastic to control the PM needs a little training but doesn’t seems like intolerable: I don’t change volume every second, and when you add “+link”, the device seems to remenber it for a few time so volume control often do not even require that sequence.
Full standby works with a long press, whatever the whatever.
Cons:
Sometimes I need to read again this post to understand how all this really works.
(Edit to add cons) Sometimes the Beolink 5000 loose the one way setting and, messing with the limits, its annoying.(Cable management in progress)
30 March 2025 at 08:50 #64776mdonald
SILVER MemberGood morning everyone,
I have a question about the Matador setup.
I finally have a bs9000, and I would also like to use it for streaming and TV, since it is beautiful when turned on, I thought about a playmaker connected with a Soundsheavenly Rj45 to aux in cable, in which I connect the TV with the rca line inputs. I have two questions:
1. when I turn on the TV and the signal arrives at the PM, does it automatically turn on the bs 9000?
2. and when the streaming music transmitted from the iPhone arrives at the PM does it turn on the bs9000?thank you for the help you will give me
MicheleLocation: Roma
31 March 2025 at 15:13 #64795 matador
ModeratorHi,
Playmaker will turn on Powerlink connected speakers but that’s all.
If the BS9000 is in standby, it will not wake up from an incoming signal.
About the auto-sense of the Playmaker when driving Beolabs, just know it can be a little bit temperamental.
Hope this helps.
