Home › Forums › General Discussion & Questions › General Discussion & Questions › Beosound 9000 MK1 fixed in Audio Option 0?
- This topic has 4 replies, 3 voices, and was last updated 1 year, 10 months ago by
Beobuddy.
31 May 2024 at 14:56 #56113
michaelmarcos
BRONZE MemberHello, folks!
I’ve just purchased and installed a BS9000 MK1. I already have a Beo4 in use wit a BS3000, working perfectly.
As long as my 9000 will be used as CD player only, I linked it to the amplifier – a Cambridge CXA81 paired with B&W 606S2 speakers – using the DIGITAL OUT.
Doing so I presume it is in default audio option 0. When I click on some buttons of the panel it says “TV OPERATED”, which confirms this.
But when I try to change the audio mode on the remote nothing happens. No blinking lights and no change at all.
So is my 9000s IR not working or when linked this way on digital out MK1 only works on option 0?
thanks in advance!
31 May 2024 at 15:03 #56114michaelmarcos
BRONZE Member31 May 2024 at 15:15 #56115 GuyModeratorIf there are no speakers connected to the Powerlink outputs the BS9000 goes to A.OPT 0 by default.
You can use this adaptor to change the A.OPT: https://soundsheavenly.com/bang-olufsen/141-2631-beosound-9000-and-beosystem-9000c-speaker-sense-adapter-gives-remote-control-functions-when-no-speakers-are-connected.html#/19-colour-white
31 May 2024 at 18:32 #56128michaelmarcos
BRONZE MemberThanks!
Do I need just one or two?
31 May 2024 at 18:59 #56129 BeobuddyGOLD MemberJust one, to simulate that there are active loudspeakers attached to the BS9000.
