Home › Forums › Product Discussion & Questions › BeoRemote › Beoremote One and Apple TV4k
- This topic has 7 replies, 5 voices, and was last updated 2 years, 5 months ago by
martinRK.
17 September 2023 at 11:24 #49026
JPurvis
BRONZE MemberHi all, sorry if this has been covered before but I was wondering if anyone knew how to access the control centre option on the Apple TV4K from the Beoremote One? Pressing and holding the green button doesn’t work, and not sure how to replicate the TV button on the Apple TV which is used to access it? Would love to be able to use the options for the Homekit from the TV with the Beoremote. Anyone managed this? Thanks in advance.
18 September 2023 at 12:24 #49027 Hiort
GOLD MemberTo my knowledge there is no possibility to access control centre using BRone. Would love that feature though.
18 September 2023 at 14:44 #49028 Millemis
BRONZE MemberIt should not be that hard to update the PUC.
Come on B&O!
19 September 2023 at 14:28 #49029 GuyModeratorThis seems related to an earlier problem: The older Beo4 PUC IR STB controller was unable to open the Apple TV Control Centre because there was no way of ‘pressing and holding the TV button’. The PUC table in my BV10-32 is however quite old, and I can’t remember if this was fixed in later releases (maybe in conjunction with Beo4 Navi, which I don’t use).
It’s especially frustrating since Apple have just added extra functionality to the Control Center with tvOS17.
21 September 2023 at 11:47 #49030martinRK
BRONZE MemberIt is possible to access the control center from a BROne with this workaround:
I use ATV4K Connected to a BV7-55 and have it controlled with the BROne with PUC as a “Beo4” product.
I have also connected the BROne directly to the ATV 4K through BT so I have the ATV as a BT source in the Remote as well.
I switch to the ATV with the BROne in “Beo4” mode. ATV is mapped to a MyButton
Then I change source via List on BROne to ATV4 (BT), and I can use the INFO button as TV/Controlcenter (long press will open controlcenter), and the MENU button as Back button
25 September 2023 at 15:19 #4903127 September 2023 at 11:55 #49032JPurvis
BRONZE MemberHey, thanks so much for the suggestion and I started trying but then got confused am sorry to say (my own failing). I think it might be that I have a first generation BROne which doesn’t have BT?
27 September 2023 at 13:02 #49033martinRK
BRONZE MemberYes, it is not possible without a BROne version with BT.
Now you have a reason for getting some new toys?
