Home › Forums › Product Discussion & Questions › BeoLink › Beolink Passive – Powerlink Socket
- This topic has 3 replies, 2 voices, and was last updated 2 years, 2 months ago by
Guy.
22 January 2024 at 11:38 #52354
ajames
SILVER MemberI have several Beolink Passives in a Beolink setup.
What I need to know that the manual doesn’t say, is if the PowerLink socket provides the 5V switching current – I need this for a bespoke application. The manual just states it is not to be used for powerlink speakers – I think it is used if you want use it as just an amplifier and accepts the 5V switching signal, but does if it is used as a Beolink product does it give out a 5V signal. I can test with a meter but wanted to know beforehand as the units are at another house.
Favourite Product: Beocentre 9300
22 January 2024 at 11:49 #52355 GuyModeratorLooking at the circuit diagram, the answer is no.
There is a permanent 5v at pin 6 of the IR socket, if that’s any use?
22 January 2024 at 12:02 #52356ajames
SILVER MemberThanks Guy, yes that answers the question – I needed a switched 5V supply.
I suppose I could use a Beolink Active with a powerlink to the Active and a splitter but that wouldn’t save me reducing the number of units in standby.
Thanks again.
22 January 2024 at 12:33 #52357 GuyModeratorI suppose I could use a Beolink Active with a powerlink to the Active (presume you mean Passive? – Guy) and a splitter but that wouldn’t save me reducing the number of units in standby.
But the BL Active will not actually produce a 5V output until it is turned on using its own IR input, so I am not sure that would work. Perhaps you could use a 5v trigger from the source audiomaster/videomaster?
