Home › Forums › Product Discussion & Questions › BeoLink › Beolink NL/ML Converter Question
- This topic has 6 replies, 4 voices, and was last updated 11 hours, 13 minutes ago by
Madskp.
8 September 2025 at 01:07 #69465
Djmp
BRONZE MemberHi,
I have Beosound 9000 connected to a BeoVision 11 via an NL/ML converter, all in the same room. Only the TV has speakers. I can select link->CD on the TV and play CDs and use the Beoremote remote to control the 9000.
Question is: with the TV off, and I start CD playback from the 9000 directly (via a button), can I have the TV turn on to provide the speakers? Seems like this should work.
8 September 2025 at 10:19 #69468BRONZE MemberHi,
Not possible to my knowledge!
And somehow understandable. Because in principle the ML side doesn’t know which “Master” it should start and on the NL-side there is no “Master”.
Presumably this could be overcome by reprogramming the BLC. Though the last BLC update date published is from December 2015! So I would say low/no chance!Still I checked this morning. Pushing a start CD button didn’t result in playback of this cd on the BS Shape (the BS9000 BLC is primary linked).
8 September 2025 at 13:08 #69475Madskp
GOLD MemberI got this functionality working with a Beocenter 9300 – 1611 converter – NL/ML converter -Beoplay V1 where I could activate the Beoplay V1 with a press on one of the buttons on the BC9300. It was discussed in this thread https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/24/ where the goal was to find out if the same functionality could be had with a MCL2AV with a connected Beogram. The thread might be a littl messy, but I know I had it working.
I don’t know if the Beosound 9000 does have any limitations in this regard, but in theory it should work.
My NL/ML converter is the latest software version.
I am wondering why you would have to press link – CD. It should be possible to assign the CD source on the BV11 to the CD player on the Beosound 9000 if they are setup as linked products
Location: Denmark8 September 2025 at 13:34 #69477ModeratorI got this functionality working with a Beocenter 9300 – 1611 converter – NL/ML converter -Beoplay V1 where I could activate the Beoplay V1 with a press on one of the buttons on the BC9300. It was discussed in this thread https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/24/ where the goal was to find out if the same functionality could be had with a MCL2AV with a connected Beogram. The thread might be a littl messy, but I know I had it working.
Perhaps the Powerlink connection (and specifically the ‘speaker on’ signal) helped in this situation. I seem to remember that the Configuration Tool mentions that a PL connection to the BL1611 is required for audio ‘front panel volume control’ in such a setup. When using just an ML connection there is no ‘speaker on’ signal that I am aware of, but you would think that the ‘data’ connection would cover this requirement.
Location: Warwickshire, UKMy B&O Icons:8 September 2025 at 15:51 #69480Madskp
GOLD MemberWhen using just an ML connection there is no ‘speaker on’ signal that I am aware of, but you would think that the ‘data’ connection would cover this requirement.
I have not tried this with a Masterlink music system, so agree that it could function in another way. I can try to do a test later thisweek with my BS Ouverture and/or my Beocenter 2 to see if they can activate the Beoplay V1 via the NL/ML converter
Location: Denmark8 September 2025 at 18:54 #69483BRONZE Memberinfo:
BS3000 – BLC – NL : start cd with button on BS3000 – NL source doesn’t start
BS9000 – BLC – NL : start cd with button on BS9000 – NL source doesn’t start
BS7000 – BLC – NL : start cd with button on BG CD7000 – NL source doesn’t start this evening (but I’m not sure this was the same before I powered everything down this afternoon, but forgot the Beosystem 7000 and the T1611 (which I restarted later on))I will do a proper reset lateron.
9 September 2025 at 15:24 #69504Madskp
GOLD MemberI have just tried now with Besound Ouverture (A.opt. 0) – NL/ML converter – Beoplay V1 (V.opt. 2)
The setup of the NL/ML converter is as follows:
Pressing CD on the BS Ouverture starts the Beoplay V1 and the music is playing through it’s speakers. So it works, at least with the Ouverture.
I have quick start timers activated on the Beoplay V1, not sure if that makes any difference, but just for the full picture.
I might be able to do some more testing later in the week with other music system, and also with a Beoplay M3 as the NL source to see if that works just as well.
