Home › Forums › Product Discussion & Questions › BeoLab › beolab 3500 and bluetooth streaming issue
- This topic has 5 replies, 2 voices, and was last updated 3 years, 7 months ago by
Guy.
31 August 2022 at 11:04 #38742
ruben1975
BRONZE MemberHello, I have a Beolab 3500 connected with a Logitec bluetooth receiver. I stream music with an Iphone 8. The issue is that the volume is very loud. If I set the volume on the Iphone at minimum its very loud. I checked the bluetooth settings of the Iphone. I’m using a cable from Soundsheavenly. Anyone a suggestion?
31 August 2022 at 11:07 #38743 Guy
ModeratorHave you tried using a B&O remote (Beo4 or Beolink 1000) to reduce the volume of the Beolab 3500? It seems that the BL3500’s default (switch on) volume is set too loud – a remote will allow you to reduce this.
31 August 2022 at 11:15 #38744ruben1975
BRONZE Memberwith a streaming device you cannot use a remote to controle the volume, only with the streaming device.
31 August 2022 at 11:27 #38745 Guy
Moderatorwith a streaming device you cannot use a remote to controle the volume, only with the streaming device.
I mean the volume of the BL3500 – this can be controlled independently with a B&O remote, regardless of the level of the line input from the Bluetooth receiver.
31 August 2022 at 11:47 #38746ruben1975
BRONZE Memberand how is that done?
31 August 2022 at 11:57 #38747 Guy
ModeratorWith a B&O remote control.
