Home › Forums › Product Discussion & Questions › BeoLab › BeoLab 2: how to switch on without 5 volt trigger?
- This topic has 13 replies, 7 voices, and was last updated 3 years, 6 months ago by
Steve at Sounds Heavenly.
21 August 2022 at 09:50 #37133
KolfMAKER
BRONZE MemberI am in a try-out project to see if I can drive a BeoLab 2 subwoofer wirelessly.
This means that I have to connect the Audio-IN of the wireless module, to pin 1 & 4 of the Powerlink. This is no issue.
What I do wonder about, is how to get the BeoLab 2 to switch from stand-by to ON. It needs a 5v signal to switch to ON.
Question
- Any ideas how to get the stand-by to ON switching done, in this setup?
21 August 2022 at 14:09 #37134 Guy
ModeratorI don’t think there’s an easy way to do it, however some thoughts:
- Perhaps you could connect the audio out of the wireless receiver to the aux input of one of these: https://shop.oneremote.dk/shop/69116-powerlink-aux-adaptor/4154-powerlink-aux-expander/
- Alternatively you could use a Playmaker. This will auto-sense a line input and switch on the PL output.
- Maybe you could take/modify the circuitry from a Beolab that already has an auto power on trigger – such as Beolab 4.
EDIT: I only considered ‘automatic’ options. It would be relatively easy to do if you are prepared to flick a switch each time you want it on!
21 August 2022 at 16:51 #37135 carolpaBRONZE MemberI am in a try-out project to see if I can drive a BeoLab 2 subwoofer wirelessly. This means that I have to connect the Audio-IN of the wireless module, to pin 1 & 4 of the Powerlink. This is no issue. What I do wonder about, is how to get the BeoLab 2 to switch from stand-by to ON. It needs a 5v signal to switch to ON. Question
The simplest solution is known as: Beosound Core or Essense mkII!
21 August 2022 at 17:29 #37136 KolfMAKER
BRONZE MemberThnx very much Guy & Carolpa!
The Playmaker, BeoSound Core or Essence are unfortunately no options for this project. I am looking at a way to integrate the streaming completely inside the speaker casing. So no PowerLink cables, only a power cable and no boxes outside the speaker casing.
So I wonder if the 5v triger is something I can create somehow inside the BeoLab 2.
21 August 2022 at 17:53 #37137Sia43
BRONZE MemberThis youtube video (https://www.youtube.com/watch?v=ivTnjK5mLV0) shows a product that seems similar to what you are planning to do. It might be small enough to be built inside the Beolab 2 (just guessing).
It seems like the trigger is going on as soon as a line signal is received and turns itself off after 6 minutes with no signal. I wanted to buy two of these for my Beolab 2000s, but unfortunately, the provided eBay link doesn’t seem to work.
In case you find the product, please let e know.
21 August 2022 at 20:25 #37138 matadorModeratorIt seems like the trigger is going on as soon as a line signal is received and turns itself off after 6 minutes with no signal.
I’ve always wonder why no “electronic Guru” ever made that kind of thing: a box that amplify audio signal enough to trigger a relay with a timed auto hold that could power up any Beolab from a line in signal.
I say this as an ignorant but theoretically it doesnt seems so from an outer world, no?
Even by retro engineering the RCA line in part of a Beolab 4/6/8 x1000.
Just a thought.
22 August 2022 at 11:19 #37139 KolfMAKER
BRONZE MemberVery interesting approach!
This is obviously the way B&O equipment handles it.
I would be very much interested in a electronics scheme, and make such to try it out.Any chance you know how such would look like?
22 August 2022 at 12:24 #37140 matadorModeratorIt would look like a little box with line-in and line-out sockets and a 5V input (or whatever is need to start the Beolab AND power the box circuitry.
Inside there will be a relay or something similar that would be triggered by the amplified Line-in signal (sound). The relay would have an auto hold loop with some sort of timing circuitry (I.E it would stick for “some” time when no sound is present and then open).
Output of the relay will trigger or not the 5V to the Beolab.
Now, Please note that I’m totally ignorant of how it could impact sound (since we’re playing with the main audio feed, but as far as I remember my electronic classes, this is not NASA technology here.
22 August 2022 at 13:11 #37141 Guy
ModeratorMaybe something like this (the 5V trigger version) would be suitable: https://www.ebay.co.uk/itm/173940637592
23 August 2022 at 21:08 #37142 tuttiviniBRONZE MemberWhy don’t you use a ‘beolab trigger cable for this?
Soundsheavenly makes them.
powmasscables makes them.
Or make it yourself. Put 2.5~5v on pin 4 and pin 7 for ground and all beolab speakers switch on…
24 August 2022 at 13:18 #37143 KolfMAKER
BRONZE MemberThanks for your suggestions!
I know both sources sell trigger cables. I prefer to build something myself, as I want to integrate my whole setup inside the BeoLab 2. The smaller I can get things, the better. So I prefer to have a scheme for such and build something myself.
24 August 2022 at 13:29 #37144 Guy
ModeratorWhy don’t you use a ‘beolab trigger cable for this? Soundsheavenly makes them. powmasscables makes them. Or make it yourself. Put 2.5~5v on pin 4 and pin 7 for ground and all beolab speakers switch on…
I am sure Steve will correct me if I am wrong, but I understand that these ‘trigger cables’ require manual intervention from the user to switch the speaker on. They don’t auto-sense the audio signal and then provide 5v to the PL pin.
I interpreted that KolfMAKER is looking for an automatic solution, hence the links provided in my posts.
24 August 2022 at 16:28 #37145 KolfMAKER
BRONZE MemberThnx Guy.
Your right, I’d like to build something (small!) that handles auto-sensing and switching from stand-by to ON, automatically.
24 August 2022 at 21:44 #37146 Steve at Sounds Heavenly
GOLD MemberHi Guy,
Yes, my cables are manually controlled, although there is nothing to stop you from using this as part of an automated process or within a home automation system if you wish. I get lots of requests to use these cables to force rear surround speakers (eg. Beolab 6000) to remain on instead of clicking on and off when the sound plays to the rear channels, hence the use of manual control in the trigger cables.
Kind regards, Steve.
