Home › Forums › Product Discussion & Questions › BeoGram › Beogram 5000 plays slloowww
- This topic has 6 replies, 5 voices, and was last updated 3 years, 8 months ago by
Evereddie.
28 July 2022 at 10:43 #36407
kentuckyduck
BRONZE MemberGood afternoon, all. First time poster. Came across a Beosystem 5000 that included the amp, turntable, cassette deck, CD player, and the monster-sized system remote. Really interested in getting the Beogram 5k working properly. It had a belt that was clearly worn out so I ordered a new one. It came today and got it replaced. It seems to operate smoothly and all functions seem OK but is clearly playing too slowly.
Any easy checks to perform?
P.S. Sure was fun threading the belt over the spindle!
29 July 2022 at 13:12 #36408 AdamS
BRONZE MemberThere are a couple of trimpots underneath the deck that are adjustable with a small flat screwdriver – one for 33rpm and one for 45rpm.
Let it run for 5-10 minutes to warm up then, using a strobe disc, adjust these until the speed is correct on both speeds.
29 July 2022 at 17:36 #36409 mexkingBRONZE MemberWhere did you buy your belt, most belts bought on the bay are worthless
29 July 2022 at 18:47 #36410kentuckyduck
BRONZE MemberThanks, Adam. Speed has been adjusted and is playing great.
29 July 2022 at 19:17 #36411Dillen
ModeratorWatch the motor current draw!
As Soren suggests; If the belt is wrong (too tight), the motor will see a too heavy sideways load, and its bearings will go bad in no time = goodbye motor. I’ve seen it so many times with cheap junk belts from Portugal and Germany sold in large numbers on Ebay etc.
Speeds being low after replacing the belt could suggest this kind of situation.Martin
29 July 2022 at 19:32 #36412kentuckyduck
BRONZE MemberThanks for the tip. What’s a reliable place to buy quality belts?
30 July 2022 at 07:31 #36413Evereddie
BRONZE MemberOnly one place for quality and reliable replacements: https://www.beoparts-shop.com
