Home Forums Product Discussion & Questions BeoCom Beocom 6000 and Virgin VOIP
Viewing 12 posts - 1 through 12 (of 12 total)
  • #36454
    carlos99
    Hello
    In the UK the media supplier Virgin is currently transitioning their telephone landline customers from the traditional wired landline to VOIP.
    I have been using my Beocom 6000 mk2 phones for years, but having been updated to VOIP I have found that my phones no longer receive calls … I have a dialling tone and can call out, but not receive.
    Virgin seem to be out of ideas.
    Has anyone else had anything similar? Does anyone have a working Beocom 6000 with Virgin VOIP?
    Any suggestions?
    #36455
    Guy
    HI and welcome to Beoworld!
    I do have BC6000s but am still on a traditional analogue connection via PlusNet, hence no experience of VOIP – yet!
    However, assuming that the cable between the phone (little 3-way junction box) and the router is an RJ11 to RJ11, have you experimented with an RJ11 ‘crossover’ cable rather than a ‘straight through’ connection? (or vice versa if you are already using a crossover.) This has fixed a similar problem for me in the past.
    It’s worth a try. And I think we are going to get more and more of these questions in the future as UK goes digital!
    Your alternative is to choose a different VOIP provider, use a stand-alone analogue-to-VOIP adaptor and just use Virgin as the broadband ‘bearer’ – the third party adaptor would simply connect to one of your router’s RJ45 sockets.
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
    #36456
    Guy
    A further thought: If your VIRGIN internet modem/router has built in DECT*, then you may be able to connect Beocom 6000s straight to it cordlessly without using the B&O PSTN. I have used Beocom 6000s like this in the past (with a German router) – there will be reduced functionality but calls in/out should work fine.
    * I just opened a webchat with Virgin to see if any of their hubs had built in DECT – unfortunately I very much doubt that the virgin ‘assistant’ understood my question! I would take his answer with a pinch of salt, but he did say: ‘Our Hub 3 and Hub 4 has a built in DECT, alright?’
    Personally I would have a look in the router’s menu and see if there are any landline/DECT connection options.
    #36457
    Keith Saunders
    FOUNDER Member
    I have had all my Beocom 6000’s Mark 2 connected using VOIP for some years without a problem. I am not on Virgin, but my comments below relate to any ISP.
    There is fundamentally two methods you can use with total success and they are:-
    1. Use a Router which has analogue sockets such as the Draytek 2830vn (Shown below)
    2. Use a Cisco SPA112 two line phone adapter (Interface shown below)
    I use method number 2 and have a free SIP account with Sipgate.
    Other points to note is that BT uses (3) wires at the master box. Pin 3 on the master box is ring indicator which in the master box is linked by a capacitor to one of the line wires and two wires go around your house to slave sockets. If incoming calls are not ringing, then your problem is related to pin 3.
    Both options above get over this problem because their outputs are as if you were plugging your phone into a BT master socket. Also check if you are using 2 or 4 wire RJ11 cable, you need four wire.
    #36458
    Keith Saunders
    FOUNDER Member
    You can view the details of the Cisco unit HERE
    #36459
    Isthatthebeotime
    I had the same issue when Virgin transferred me over to VOIP, took days to resolve with trial and error but what finally worked for me was deleting all BeoCom’s off the BeoLine transmitter, unplugging it for awhile then powering it back up and reinstalling the phones… hope it works for you
    For some reason before that it would ring once, pick up then hang up.
    #36460
    huwrugby
    Well, I have solved the issue of Beocom 6000 not accepting incoming calls by moving away from Virgin’s fibre phone service. I’ve ported my home phone to a separate VOIP  provider – https://www.voipfone.co.uk/ – others are available. Using a generic VOIP adapter/gateway – Grandstream HT-801 VoIP adapter – the whole Beocom system functions seamlessy again – despite using a very old PSTN base. Virgin take note
    #36461
    Guy
    Thanks for the update and I am glad that you found a solution.
    I think many more landline users will have compatibility problems when the UK analogue telephone network is switched off in 2025. My provider is PlusNet and they have no current plans to offer a digital landline connection (despite the PlusNet Hub 2 router having a phone socket!), so I may well be looking for a third-party VOIP provider when the inevitable happens.
    #36462
    tmorgan85
    I’ve same problem after Virgin landline migration to broadband – can call out but no reception of incoming calls. It took 3 VM “engineer” visits before I was told there wasn’t a fix Have been using two 6000 remotes and a 2500 handset for decades. They’re design classics, quality products which last a lifetime, I love the aesthetics, and on a practical note I’ve not found a replacement for 6000s which wall mount.
    BT equipment I’ve bought as replacement does receive calls, but would be surprised if it lasts a single decade
    #69529
    Steve Moores
    This issue has probably been resolved now by many / most of you, but I outsourced my grievance to a very helpful small independent vintage telephone specialist company who weren’t aware of the problem. I sent them my Beocom 2 Mk1, they disassembled it to ascertain the issue and how the B&O design was supposed to work, then designed and built me a small box (like a plug in adapter for between the Beocom 2 and the wall socket). It works perfectly alongside my Panasonic DECT phones within the home.
    Company details for anyone who’s interested:
    https://www.vintagetelephony.co.uk/
    Email: vintagetelephoneysales@virginmedia.com and address to Chris.
    The cost charges was very small compared to the number of hours I’d spent pondering over various threads on the issue. Very happy with the solution they’d resolved, and it’s been working faultlessly for about 9 months now.
    Favourite Product: Overture
    #70284
    vallaska vallaska
    I had to connect mine through the base station using a standard phone socket on the back of my router—once that was in place, everything worked fine with the BeoCom.
    #70290
    Steve Moores
    Thanks, that’s helpful to know. I’d tried that, used earlier splitter boxes, in fact everything I had in my collection stored over the years since 56k dial up. So tried these guys, who disassembled my Beocom and built a box around its components.
