Home Forums Product Discussion & Questions BeoCom Beocom 5 software
Viewing 12 posts - 1 through 12 (of 12 total)
  • #53239
    deaddruid
    FOUNDER Member
    I’ve recently acquired a Beocom5, that I wanted to add to my existing Beoline2 + 3x Beocom 6000 mk 2 setup. However the Beocom5 can’t detect the Beoline2. Versions:
    Beocom5 (type 1801) is at software version 1.70 (26 Jan 2010),
    Beoline2 (type 1130) is at software version 1.5 (26 July 2006).
    Do I need a software update to either the Beoline2 or the Beocom5 to make them work together?
    If so, is there a way to do it myself, or do I need to find a helpful dealer who can update them?
    Mark
    Favourite Product: Avant 32 DVD
    #53240
    Guy
    According to the compatibility table they should work together:
    Compatibility Table
    From the Type number I assume that your base station is a Beoline EU Mk2, so you need to read note 2 above.
    Two things to check:
    • Are you opening up the Beoline to registration by powering it down and then up again?  I think it stays open for 5 minutes.
    • Are you 100% sure that no other handsets have been registered to the Beoline – I think the maximum is either 6 or 8?
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
    #53241
    deaddruid
    FOUNDER Member
    Guy, thank you for your thoughts.
    I originally bought the Beoline with one Beocom 6000 mk II from Denmark, a few years ago. I’ve since added three other 6000 mk II phones and then deleted one. The list of registered phones viewed from a 6000 mk II (pressing the INT button) has only three slots used (1, 2 and 4).
    I’ve tried opening the Beoline for registration from one of the 6000 mk II phones, and when that proved ineffective, I switched the base off and then on again. No dice.
    I have tried resetting the Beocom5, but haven’t tried resetting the Beoline yet, as I don’t want to lose all the programmed numbers unless I have to.
    I’ve just tried adding a new Beocom 6000 mk II, and it went straight in as #5, but the Beocom5 still doesn’t communicate with the base. So the base will clearly take more handsets, implying a problem with the Beocom5.
    So it currently looks like either the Beocom5 is faulty, or there is a software incompatibility.
    Mark
    #53242
    Guy
    Try going into the Settings menu from the centre button. Scroll to ‘Base’ and then ‘Remove Handset’. Using the wheel will then scroll through all the registered handsets. Pressing INT and scrolling will only show the handsets currently connected.
    #53243
    deaddruid
    FOUNDER Member
    Of course! That explains the gap at #3 – which was the phone where I pressed the INT button.
    It now shows 1, 2, 3, 4 and 5 (since I added #5 this morning, as a test) so there should be plenty space for the Beocom5. However it still just says “”Searching base Wait…”.
    Mark
    #53244
    Guy
    Hmmm … I think I would try a base reset next.  I am not sure but perhaps you can transfer the numbers to be stored as a Personal Phonebook on one of the BC6000s, and then transfer back to a Common setting where numbers are shared later.  This is within Settings, Handset, ‘Handset Type’ but check the manual to be sure – and maybe write all the numbers down (or take a video as you scroll through the phonebook).
    If you do reset the base, try registering the BeoCom5 on its own first.
    #53245
    deaddruid
    FOUNDER Member
    I’ve now tried resetting the base. The Beocom5 still doesn’t talk to it.
    I did save the phonebook to one handset, but ridiculously, there’s no way to copy it back!
    Mark
    #53246
    deaddruid
    FOUNDER Member
    I think I’m going to have to find someone with a Beoline2 base so that I can try to connect the Beocom5. That way I’ll at least have a little more information – if it works, then the problem is my Beoline2, if it fails, then it’s more likely the phone.
    Mark
    #53247
    Guy
    I think I’m going to have to find someone with a Beoline2 base so that I can try to connect the Beocom5. That way I’ll at least have a little more information – if it works, then the problem is my Beoline2, if it fails, then it’s more likely the phone. Mark
    That’s a good plan – or you could try it with any of the compatible bases shown in the table. Beoline 2 should be the most straightforward, however.
    #53248
    deaddruid
    FOUNDER Member
    A very strange thing happened. I took the Beocom5 to a kind friend who allowed me to try to register it to his base, which again failed. I then went home, and forgot to take the phone out of my coat pocket. This morning I remembered it, put it on the charger, tried registration… and it worked straight away.
    Before my initial attempts to connect the phone I had reset it to factory settings. It wouldn’t connect. Something seems to have changed by letting the battery go flat.
    Very odd.
    Mark
    #53249
    Guy
    Excellent news!  I have had similar experiences with BeoCom 6000s not registering for ages, and then suddenly connecting out of the blue!
    #69890
    Alex Settelvan
    I managed to update mine by using an old Windows laptop with Internet Explorer 8 and the Beo5 software, then connecting through USB—took a couple of tries before it recognized everything.
