I have a Beocentre 9500 and have tried linking a Technics SL-Q2 turntable through a preamp in to the 7 pin Din phono input on the 9500.
The problem starts when I try and play a record on the turntable, the output volume on the 9500 is non-existent unless you turn the volume to max and only then you hear it very faintly. I have also tried it in the Aux input and the same happens. Both input and output volumes on the preamp are at max.
It’s worth noting that the turntable play as should on another device
Can someone steer me to a solution.
