Home › Forums › Product Discussion & Questions › BeoCenter › BEOCENTRE 9300 Tape Malfunction
- This topic has 4 replies, 3 voices, and was last updated 5 months, 1 week ago by
Guy.
11 May 2026 at 16:11 #123539
Victor Mazella
SILVER MemberHi, I inherited a Beocentre 9300. Unfortunately the tape section does not function. When attempting to play a tape I can hear clicks but no motor noise or movement. Advice to possible cause would be appreciated such as belts or more serious malfunction.
Many thanks in advance
18 May 2026 at 09:28 #123648 HiortGOLD MemberIm guessing now, but belts would be my first bet.
18 May 2026 at 10:24 #123650Victor Mazella
SILVER MemberThanks for your reply. I found a video showing how to access the working parts although it was for a cd fault. Not sure of my skill level with this but will proceed with caution and if it’s not the belts will have to source someone who can repair.
23 May 2026 at 05:37 #123719Victor Mazella
SILVER MemberHappy to report that I had success with fitting the three belts for the tape section and the tape is now fully functioning. Not bad for someone approaching eighty with age related hand trembling.
You must be logged in to view attached files.Location: Scotland
23 May 2026 at 18:38 #123727 GuyModeratorHappy to report that I had success with fitting the three belts for the tape section and the tape is now fully functioning. Not bad for someone approaching eighty with age related hand trembling.
Excellent work – thanks for letting us know that was the solution, and enjoy your tape deck! 😊
