Home › Forums › Product Discussion & Questions › BeoCenter › Beocentre 2500 tape mechanism repair
- This topic has 10 replies, 4 voices, and was last updated 3 years, 5 months ago by
Die_Bogener.
31 August 2022 at 10:44 #38731
Troy74
BRONZE Member31 August 2022 at 11:09 #38732 spassmakerBRONZE MemberHi
I’m not shure but maybe into the gap on the toothed levelarm above the last theeth and then a little right.
Regards
Christian
31 August 2022 at 11:16 #38733 GuyModeratorI concur with Christian!
31 August 2022 at 11:27 #38734Troy74
BRONZE MemberWow! Guys thanks so much that diagram is priceless!
31 August 2022 at 11:30 #38735Troy74
BRONZE MemberIt’s hard to know how to set the lever arm into the head’s cog ?♂️
31 August 2022 at 11:33 #38736Troy74
BRONZE MemberAs the head can spin 180 degrees does anyone know what position it should be in default ? if I look directly at the tape player from the front with the head at the bottom is the default position all the way to left or right position ?
thanks
31 August 2022 at 12:08 #38737Die_Bogener
BRONZE MemberThere is not one fixed position… there are 2 !
It’s an “either or” position. The spring shall fix it in side 1 or side 2.
It’s an over the peak snap construction.
Just snap it in the gap next to the teeth…
31 August 2022 at 14:35 #38738Troy74
BRONZE Member31 August 2022 at 14:35 #38739Troy74
BRONZE MemberThis does look right
31 August 2022 at 14:52 #38740Troy74
BRONZE MemberI understand there may no fixed position but I need to know how to mount the white plastic leaver and n relation to the head position
31 August 2022 at 17:00 #38741Die_Bogener
BRONZE MemberThe gear does only the movement, the head has it’s own justage … see the red stuff? This is for the head position.
The gear should only be in something symmetrical end position when switching side 1 – 2
I think there is one tooth wrong… just 1 tooth in endposition looks a little bit weak overlap… how does ist look in the other position? 3 Teeth?
