Home › Forums › BeoWorld around the world! › Nordic › Beocenter 9500 strange behavior (tape door crazy)
- This topic has 3 replies, 2 voices, and was last updated 3 years ago by
Guy.
17 March 2023 at 02:19 #44766
BC9500F
BRONZE MemberHello dear b&o addict !
A strangeness on my BC-9500, maybe can you help me ?
When tape & cd doors are “closed” and i put in standby my unit, the tape door open automaticaly !!! i don’t understand.
Another situation, Tape door closed & Cd door open > i put standby the unit,e the Cd door closed of course but Tape door open….
lol…. a ghost ?
What do you think ?
Cheers
Axel
17 March 2023 at 18:51 #44767 GuyModeratorWelcome to Beoworld!
A strange fault! Are there any strange indications with the lower display panel? Do you leave the unit connected to mains power when not in use?
There could potentially be problems with the control processor caused by a flat backup battery on the processor board. This can be compounded if the unit is removed from mains power when not in use. The battery is replaceable if you are happy with disassembly and soldering; there is advice on the forum if required.
Alternatively it could simply be loose or broken connections between boards/motors/sensors.
19 March 2023 at 20:03 #44768BC9500F
BRONZE MemberEvening Guy, many thanks about your answer…. I was stupid ! 15 days ago, i changed the motor and i inverter the 2 cables when solder… haha ! Now it work perfect. THX AGAIN… Good evening. Best regard.
20 March 2023 at 11:53 #44769 GuyModeratorAh that was an easy fix! Thanks for letting us know – one day someone else will make the same mistake and this thread will help them fix the problem!
