Home › Forums › General Discussion & Questions › General Discussion & Questions › Activate Camera input on BV6-23 with Beolink 1000
- This topic has 5 replies, 4 voices, and was last updated 3 years, 8 months ago by
Tignum.
29 June 2022 at 10:43 #35827
peppsModeratorHello all,
I have a Beo4 upstairs in the living room with my main system, but operate the kitchen BV26 with a Beolink 1000. The kids have a Nintendo Wii connected to the BV26 through the RCA sockets on the side panel which can be activated by the Beo4 with Camera.
I’m looking for some help to find a key press combo to activate the Camera input on my little BV26-23 with a Beolink 1000 remote control.
Can it be done?
Julian
Favourite Product: Beosystem 6500
29 June 2022 at 11:17 #35828 GuyModeratorAs far as I know CAMERA is not possible using BL1000. The Camera socket is suppose to ‘auto sense’ and switch to that input, but I never got that to work on my BV6-26 or 6-23.
Any chance that you could move the Nintendo to the DVI/PC input and then access using BL1000 by pressing SHIFT then STORE?
29 June 2022 at 14:15 #35829 peppsModeratorHi Guy,
Thank you for your response (I need to go and delete my reply to your other thread now.)
Tricky to convert the Wii lead to a DVI. Plus I would miss the audio.
I have been able to get the image to appear by removing and reinserting the yellow video lead. I guess that’ll be it for now unless another Beoworlder pulls a rabbit from a hat.
Julian
2 July 2022 at 11:20 #35830 StoobieGOLD MemberHow about using one of these and plugging into a scart socket. The scarts are usually easier to set up and control. That assumes you have a free scart input.
Stoobie
4 July 2022 at 21:38 #35831 peppsModeratorHow about using one of these and plugging into a scart socket. The scarts are usually easier to set up and control. That assumes you have a free scart input. Stoobie
Hi @Stoobietoo,
You’re right; I’m using the two scart inputs already. T’was the right call though if I had a spare input.
Julian
5 July 2022 at 07:17 #35832 TignumGOLD MemberWhat about finding another Beo4? One can never have enough of those 🙂
