Home Forums Product Discussion & Questions BeoLink BL3500 connected via BLC [SOLVED] Reply To: BL3500 connected via BLC [SOLVED]
#70355
carolpa
@carolpa
: Yes, the BL3500 BLC set is still in place so nothing has changed. How would you deploy and setup the various BLC’s ti allow the NL be the central – not sure I understand how it would be possible to connect in a different way, or?
Should I understand that I make my BLC-BV10 the primary unit and then change so that the primary connection is set to the BLC-BV10 and the seconday BLC to whatever would be of interest for the specific BLC. Something like this then for the BLC-BL35:
Doing so I’m able then to play both CD (BS9000) and InTune (Moment) but neither able to get it to play N.MUSIC or pulling the normal audio from the TV-tuner. Unfortunate when I try to use the B&O App to play Deezer I get a brief error message saying – “This product does not support Deezer in the Bang & Olufsen App. To use this product with Deezer, use the Deezer app.”. What does work is that I can start N.MUSIC to the BL3500 via a for example Beo4 remote which I then able to see that is playing in the B&O App indicating that the source is Music from Beosound Moment and can’t control anything, meaning I can’t init play, pause or stop the music, only able to see what is being played from the Moment including that I can see device menu that music is being played on the BLC-BL35.
So to me it seems that it’s not possible to use setup a multi-room using a BLC and BL3500 since the B&O App won’t support it.
Skip the primary and secundairy connection altogether. All my BLC’s are set primary and secondary to themselve! This will make the operation unnessecary  complex.
But is the BL3500 BLC still set as ASlave? If so, then this is incorrect! ASlave is used if a sole ML device without speakers connected, adds sources to NL. The BLC should be set as AVmaster.
You should be able to play Deezer on the Moment and JOIN a BLC. But how to start Deezer on the BL3500 then? A question to be cracket.
