Home › Forums › Product Discussion & Questions › BeoLink › Beolink NL/ML Converter Question › Reply To: Beolink NL/ML Converter Question
I got this functionality working with a Beocenter 9300 – 1611 converter – NL/ML converter -Beoplay V1 where I could activate the Beoplay V1 with a press on one of the buttons on the BC9300. It was discussed in this thread https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/24/ where the goal was to find out if the same functionality could be had with a MCL2AV with a connected Beogram. The thread might be a littl messy, but I know I had it working.
Perhaps the Powerlink connection (and specifically the ‘speaker on’ signal) helped in this situation. I seem to remember that the Configuration Tool mentions that a PL connection to the BL1611 is required for audio ‘front panel volume control’ in such a setup. When using just an ML connection there is no ‘speaker on’ signal that I am aware of, but you would think that the ‘data’ connection would cover this requirement.
