Home Forums General Discussion & Questions BeoWorld Feature / Problem Connecting BeoSound 9000 to BeoVision 11 problem Reply To: Connecting BeoSound 9000 to BeoVision 11 problem
#65249
Guy
Hi and welcome to Beoworld!
Effectively you have two devices connected directly to your Beolabs, which you shouldn’t do – for reasons that you have discovered, but you could also cause damage!
You have at least two options:
There are possibly other options making use of the aux input of the BeoSound (or AV input of the TV) but these may not be as user-friendly.
EDIT:  Here’s a cable from one of our Sponsors that makes use of the TV’s AV input:  https://soundsheavenly.com/tv-input/138-2295-9-pin-av-cable-for-beovision-11-12-new-generation-avant-v1-and-beosystem-4-powerlink-input.html#/5-length-5m
