Home › Forums › General Discussion & Questions › General Discussion & Questions › Playmaker mk. 1 configuration issues › Reply To: Playmaker mk. 1 configuration issues
I set up my Mk1 Playmaker today and experimented with a few things including factory reset, followed by different methods of setup.
Some observations:
- I too was not able to setup or access the Playmaker using the B&O app – I saw the same messages as Madskp.
- I was able to use the old BeoSetup app (no longer avail) to do a ‘first-time’ setup the Playmaker. As described in the instructions, I had to first go into the iPhone wireless menu, disconnect from my home wifi and connect to ‘Playmaker_AP’, whereupon the BeoSetup app (but not the B&O app) could be used to complete setup.
- After a further factory reset, I was able to complete to complete a ‘wireless setup via cable’ using a laptop (switched to airplane mode) and the following instructions:
I found the Playmaker setup menu under the published IP address of http://169.254.11.22 – so perhaps it is indeed just different for the Mk2 Playmaker (or perhaps it is only for first time setup via cable – I haven’t seen a Mk2 manual).
I am not sure how the above helps @TWG, but am happy to experiment further if required. It would be useful to know if his Playmakers are Mk1 or Mk2, but I would recommend webpage setup using a computer on his home network to find the individual devices by IP address (look in computers Network folder for Playmakers) and change settings as required.
