BeoWorld Logo
Home Forums Product Discussion & Questions BeoCom BeoCom 6000 Mk2 Display Repair Reply To: BeoCom 6000 Mk2 Display Repair
#55491
Guy
    • Warwickshire, UK
    Hi and welcome to Beoworld!
    The little rubber piece goes into the same sized slot in the removable clear plastic piece (just above it in the first picture).  When assembled correctly, it connects the display contacts to the main PCB.  Experiment a little and I am sure that you will work it out!
    The connector top right is for the headphone socket and IR transmitter (for remote control of B&O audio/video devices).   It’s a while since I disassembled a Mk2, but I think that should also connect to the top of the main PCB.
