Home Forums Product Discussion & Questions BeoLab Streamer for Beolab 5 Reply To: Streamer for Beolab 5
#43194
NQVHNWI
There is no problem to use the Lyngdorf with Beolab 5, I did it many years, it is absolutely transforming the sound coming out from the Beolab 5 after running the RoomPerfect setup, it is really night and day. As long as you don’t use the Speakers output, you only use the PREAMP part of the Lyngdorf. I don’t have experience connecting them by line in, possibly you will be able to control the volume with the Lyngdorf and power them on. Give it a try and you will see, don’t forget to set the Lyngdorf not full range and start with volume at -50. But it would really be a pity to not use the full path in digital and use the BL5 internal DAC that is truly excellent. But you will need a Beo4, that’s for sure.
Think I pretty much said that…..
“Do not send an Amplified signal as this will damage the BL5s. IIRC 2V is the max analogue voltage.
If there is a non-DAC coax output or line level it should be OK but please please confir with BnO”
