Home › Forums › Product Discussion & Questions › BeoLink › Beolink Active 1636 PC Input › Reply To: Beolink Active 1636 PC Input
I can confirm that these connections are correct. Data – and Data + are the differential data lines and are the same as pin 1 & 2 on the Masterlink socket. The SL_config works like the ML_config in defining direction of data.
Thanks Keith – I don’t think I’ll be able to do much with the data etc, and will just have a think about other uses for the pin 3 and 5 audio outputs (if they work). Thinking about these, the user manual for the Beolink PC shows a ‘SOUND IN – no connection; for future use’. I think that ‘SOUND in’ implies ‘a sound into a computer’, so perhaps the Beolink Active replicates this with a line-level sound ‘into the computer’. Perhaps B&O envisage people wanting to record digitally on their PCs, or do some processing on the computer’s sound card?
The later Beoport has a (usually covered with a sticker) audio output that could be used for the same purpose.
