Vasco Machado Vaz
Forum Replies Created
  • in reply to: Beogram 8000 – resistor R25 #73481
    Vasco Machado Vaz
    Thank you Dillen
    Vasco
    in reply to: Beogram 8000 panel fault ?? #72926
    Vasco Machado Vaz
    Hi Dillen
    Thank you for your reply [I know you a busy man on this forum].
    The Beogram wake up once I replace the fuse transformer  . But now I am at odds with this behavior:
    If I swap a PBC1 for other that I have or only if I disconnect it and reconnect to the plate the fuse blows.
    Upon a new fuse I press play and it start playing the record but the arm stop and return to the start position  after a few revolvings.
    What can explain such behavior
    Kind regards
