beolover.vn
Forum Replies Created
  • in reply to: Beocord 9000 tape calibration never stops #51805
    beolover.vn
    Hello, I also have a Beocord 9000 device encountering a similar issue with the Rec Cal not stopping. After a preliminary check, I used a multitester with a diode test function. When I applied it to pin 2 of 13P24, the Rec Cal function worked correctly. I’m not proficient in technical matters, and my capabilities only extend this far. I hope fellow enthusiasts can provide assistance.
    YouTube link of my device:  https ://youtu.be/Zur4gGsA4pY
    in reply to: [HELP] Replace IC9 8355 Input/Output in Beocord 8004. #51649
    beolover.vn
    When pressing play, the motor does not engage, and the heads do not lift up.
