Forum Replies Created
stotty1111GOLD MemberWhen first plugged in is there not an indication on the inbuilt screen , 4 x * if so try inputing 4 x 0, that might work, the other route might be to contact b&o with the serial number and an explanation , they have in the past given me the original pin code
stotty1111GOLD MemberBest of Robert Palmer cd on an Ouverture through Beolab 6000 actives — excellent!! 😉
stotty1111GOLD Memberare the 2 x vent grills on the underside clear of debris, just a thought!!
stotty1111GOLD MemberHi Yann,
The ‘sort of’ B&O dealership in Nantes use 111 Services. I say sort of because they deal in a wide range of ‘stuff’, not just B&O!
There is a dedicated B&O outlet in Rennes although my experience was a little negative, the owner got a little short with me because he would not give me any details of 2nd user tv’s. They at that time, 2 years ago, also used 111 Services in Nantes or so I was lead to believe.
I cannot find the relevant telephone numbers, addresses etc as they are filed in an old laptop, if time permits tomorrow or wednesday i will try to find said info!
stotty1111GOLD MemberI don’t know, the repair place did work for 2 x B&O outlets, the technician worked thro’ lots of suggestions from B&O all to no avail!
stotty1111GOLD MemberOk, about a week on from the remote clean, and still no repeat of the problem, must have been the remote!
Thanks for all suggestions! 😀
stotty1111GOLD MemberIt was a 7-40 Mk6, and had lost picture but the sound was ok!
stotty1111GOLD MemberI live in Brittany, Finistere, nearest B & O vendor is in Rennes, about 150 miles away, followed by Nantes 170, locally ‘stuff’ is a bit like hens teeth, dealerships are also a bit’snooty’ probably because my french is not top line!
Hey ho life’s a bitch!!
stotty1111GOLD MemberHi Tignum
Sorry about my delayed response, other ‘stuff’ cropped up, I build and sail r/c model boats, and am known for solving probs with control systems. There are lots of times when I wish I wasn’t!
Ok, I will have a look later in the week and maybe decide to go with no foam. A friend thinks she may have a piece that might work, time will tell!
stotty1111GOLD MemberSo, an undisturbed nights sleep, I assume the problem was remote based as I did not change any setting with the ‘system’. Time, pardon the pun will tell!
Thank you both for the input.
Tony
stotty1111GOLD MemberNo hdmi sockets on the tv, scart used, with a computer connection, hdmi at the pc to dvi-i at the tv, and, basic boxes so no auto updates!
stotty1111GOLD MemberAh could be, the control has been playing up recently, replaced batteries, sort of ok, stripped it down this morning and gave it a spray with switch and contact cleaner, it seems to be working ok now but maybe tomorrow when the solvent carrier has vapourised will tell me more!
stotty1111GOLD MemberOk, the BC 2 sits on the motorised stand turntable under the tv, the tv is the master and the BC 2 the slave in the ML setup.
Looked at the BC 2 menu, and there is nothing listed or activated, just a reference to use the TV for timer setup.
The tv does not have a numeric system mounted, I use 2 x digital boxes, 1 for terrestrial french tv and the other for satellite english freesat tv, both these do not have anything programmed.
I am at a complete loss! I will give it another go tonight, and maybe reboot the tv and the BC 2 tomorrow, but I don’t think that should have any effect on the system.
stotty1111GOLD MemberBut would that contol the tv?
stotty1111GOLD MemberNo, I’ll check after lunch!!
