sandor.szucs
Forum Replies Created
Viewing 7 posts - 1 through 7 (of 7 total)
  • in reply to: Beovision 11, No Picture #99543
    sandor.szucs
    SILVER Member
    So, I got and installed the new capacitors but it made no difference – there still is no display (picture).
    Is there a way I could test power supply PCB 04 while it is out of the TV on its own ?
    After I replaced the capacitors, I had PCB 04 assembled to the TV and using the service manual diagnostic flow chart (for symptom: No Picture) I did the checks and ended up with the conclusion that PCB 01 should be replaced. However, I am still not sure after those checks if PCB 04 is in fact OK or NOT OK. The service manual does not offer any test methods to determine if a particular PCB circuit functions OK or NOT OK.
    Could someone help me with this please?
    in reply to: Beovision 11, No Picture #76390
    sandor.szucs
    SILVER Member
    Anybody who is looking for the same capacitors will find them at the web address bellow:
    https://www.aliexpress.com/item/1005010544497927.html?spm=a2g0o.order_list.order_list_main.9.7eeb1802PGeDSR
    in reply to: Beovision 11, No Picture #76348
    sandor.szucs
    SILVER Member
    Hi, Madskp,
    Thanks very much for your help.
    sandor.szucs
    SILVER Member
    I assumed I could upload files via “Choose File” bellow. I guess I can not navigate this properly yet……………
    Will try uploading again.
    sandor.szucs
    SILVER Member
    Thank you for your continued support.
    I have drawn up (what I understand) is the correct configuration for a cable from Power Link to AV and a cable from BS 3000 AUX to AV. Please check for me if they are correct (see files attached).
    One question remains: Which pin should I solder the breaded wire to at the AUX end? Or should I not need to bother with that?
    sandor.szucs
    SILVER Member
    I have made a cable with one end 8 pin mini din (actually I just cut off one end of a spare power link cable) and the other end 9 pin mini din. But I am not sure if I soldered  the correct wires on the 9 pin connector. I followed the diagram you suggested (the best a novice like me can) so I soldered the green cable to position 9, the shield wire I twisted and soldered to position 8 and the brown wire I soldered to position 7 on the 9 pin mini din.
    Is the above the correct thing to do?
    Or should I solder the light grey shield wire from position 8 of the 8 pin mini din to position 8 of the 9 pin mini din.? Or have both those shield wires soldered to position 8 of the 9 pin mini din?
    By the way, I like the idea of going from the AUX of the BeoSound 3000 to the AV of the BeoVision 11 however, the AUX socket is a 7 pin. Can I just cut off the centre pin of the power link connector?
    sandor.szucs
    SILVER Member
    Hi, thanks very much for your help.
