robert_glatzel
Forum Replies Created
  • in reply to: Replacement gear for century 2000 #45968
    robert_glatzel
    Wow, thank you so much! This is perfect. just placed my order.
    Thank you!
    robert_glatzel
    Hmm unsure which part this refers to ( very new to this ๐Ÿ™‚ ), but it’s the American one.
    I haven’t noticed anything working incorrectly, although I’ve only used it for cassette tapes.
    And great! I will go ahead and give this a try then!
    robert_glatzel
    Ah okay thank you for the response!
    I’m unfamiliar with the names of the parts but I believe PCB 5 is the one after the transformer that sits under the door motor, correct?
    And 10 Mains seems to be the one where the power cable is plugged into and then has a wire that runs into the transformer, correct?
    I have switched both mentioned parts out for European versions, so I think if I were to change the wiring on the transformer it would work just fine…?
    in reply to: Looking for help with repairing a BeoSound Century 2000 #43339
    robert_glatzel
    Oh great!
    Thank you for your replies!
    No, I did not check that board, as I only saw the smoke come from the bottom left of the unit. I will take a look after work.
    If I’ve replaced the transformer, the pcb in my photo, and potentially this piece, are there any other pieces that might need to be replaced?
