Forum Replies Created
paul.70
BRONZE MemberThanks @paul.70 for sharing. Multicare is the offical B&O kit or a 3rd party provider? The color seems unchanged? How does it connect with the Shape and is there a delay?
Hi @steve1977 the kit comes directly from B&O, when they return your freshly painted chassis from the beogram you supply. Then Multicare of Leeds do the rest. The colour as I understand was only changed for the limited run that B&O upgraded and sold directly by them. I have wire connected mine to the Beosound Core inside my shape via the line-in connector. There is a small delay between the Beogram and the shape but it sounds great and I was shocked at how little needle noise there is.
Any further questions please feel free to ask.
paul.70
BRONZE MemberHi Steve.Just got mine back (4002) from Multicare. It sounds amazing connected to my Shape. I made the cabinet myself complete with integrated Halo remote charger and music sync LED’s.
paul.70
BRONZE MemberI think it looks great. I would love to know if they will offer the same service for the BS9000, as they did for the 4000c program?
paul.70
BRONZE MemberCouple of things here…..firstly does anyone have any pictures of whats inside the new turntable? Secondly I read somewhere that B&O where offering to upgrade existing 4000x turntables to the new spec…..what are they changing out and more importantly what are they going to do with the component/equipment they remove during this excercise….
There’s no question that it looks very attractive, and that its modelled on a 4002 unit. In my view it lacks the over engineered and massively complicated charm of a 4000 deck, the boolean logic controlling the 4000 is a work of art in itself…and the delicate reed relay stop start circuit is just so baffling that i suspect it must have been reverse engineered from an alien spacecraft dug up from the gobi dessert ;¬) And does anyone know what the device is that Eric is injecting the circuit board with is, soldering flux perhaps. Looks like he is upgrading an existing deck from the oxidation on the internals, an old Elco Capacitor and the tone arm solenoid coil looks like it has warmed up the insulation over time…is image 2 the finished article Steve?
Hi Steve.
You must be logged in to view attached files. -
