norberto_
Forum Replies Created
  • in reply to: Beoplay M5 – No serial number #44331
    norberto_
    HerlufHansen wrote:
    Hi guys. Sorry I didn’t write yesterday – Was a bit busy. I’ve added the guide I’ve received from B&O support. There is a direct download link from B&O to the SW inside the PDF Hope it works for you guys too ?
    Top Man!
    Serial and Item number is restored, then i had an auto fw update to 1.25 immediately then to 2.1.50868.22855122 after that.
    Thank you so much again.
    Kind regards,
    N
    in reply to: Beoplay M5 – No serial number #44327
    norberto_
    HerlufHansen wrote:
    Hi there. Sure I can. Will find it later when I get off of work. ?
    Really appreciate it!
    Thank you
    in reply to: Beoplay M5 – No serial number #44325
    norberto_
    Hi Guys,
    I have the same issue with the M5.
    Who can i contact for the firmware to fix it?
    @HerlufHansen
    is it possible you can give me that special firware?
    Thank you
