Nicolaas Dekker
Forum Replies Created
  • in reply to: 3 out of 4 Beolab 8000 not working anymore #63677
    Nicolaas Dekker
    Do you know if the Beolab MK2 also have the wrong foam ?
    in reply to: 3 out of 4 Beolab 8000 not working anymore #63676
    Nicolaas Dekker
    Yes it works !!
    Thanks for your help !!
    i am going to clean this one and order the sets of foam for the inside.
    I saw them online as sets. i also saw a long thread about it with you in it. Do you know where to get te good one for the best price ?
    in reply to: 3 out of 4 Beolab 8000 not working anymore #63675
    Nicolaas Dekker
    Thanks again !! going to try it now or tonight !!
    Will keep you informed !!
    in reply to: 3 out of 4 Beolab 8000 not working anymore #63670
    Nicolaas Dekker
    Hi !! Thanks for your quick reply !! is the alcohol you mention a special one ? i have 96 % from the pharmacia here. can i use that ?
    Do you think that the damage on the lines you see in my pic can already make the speaker not work ? it also seemed like the rca connectors made a bad contact before the speakers went to complete silense. when i touched the rca plugs it sounded like the did not make a good contact.
    I was searching for B&O and came on Marktplaats to the Beloab Penta speakers. i use to own 4 of them in the beginning of the 90ties and i think the seed has been planted to buy  a set on markplaats in the future.
    the active ones. Still remember the sounded great. I sold them with the house in those days……
    And yes !! i am dutch. I live in the south of Spain since 2017.
    Best regards !!
    Nico
