kknyc
Forum Replies Created
Viewing 16 posts - 1 through 16 (of 16 total)
  • in reply to: BEOGRAM 5500 stutters and bounces on return [video] #73269
    kknyc
    SILVER Member
    hi Mark, thanks for the reassurance👍.
    I’ll revisit and repeat the steps in 5.1 (steps in 5.3 are correct as the ‘Pickup Arm Set-down‘ points are correct to the mm). Maybe the arm location was incorrect when I reattached the wire guide?
    in reply to: BEOGRAM 5500 stutters and bounces on return [video] #73232
    kknyc
    SILVER Member
    HI Mark, Yes, as stated earlier thats what I followed. Could you add anything from your own experience that might help?
    Could you offer any insight to the questions I asked in my previous post?
    is this a normal return? (speed seems fast)
    in reply to: BEOGRAM 5500 stutters and bounces on return [video] #73086
    kknyc
    SILVER Member
    today I finally got a chance to open up the Beogram again. Without that clip, you could see the cable bunch up (at “A”) against the Platterlock then bounce back after the arm return ends.
    @Dillen
    Thanks for the tip, I hot glued the cables  (adjusted by the clip dents in the cable)—it helped some, the bounce is less. 👍
    I’d love to find a new/nos/replacement clip(s), Please let me know if anyone knows of a source or has 5500 parts for sale. Thanks
    While this helped. theres still a little ‘stutter’ at the end of travel. It sounds and looks like the gears are still trying to push the arm after its reached its ‘end of travel’  (see attached vid clip). This is my 1st B&O so I have no idea what the ‘norm’ is, could an experienced ‘Beo owner’ confirm…
    • is this a normal return? (speed seems fast)
    • Are there any marks on the gears (like a car engine) to set ‘top dead center’ so the gearing and ‘end of travel’ is calibrated?
    • Is there a way to set the ‘end of travel’? (I only see stylus ‘set down’ points in the Service Manual as an adjustment)
    Thanks for an insights
    <PS Lastly, how do we add vid clips in the posts in this forum? —I can’t seem to figure that out 😅>
    in reply to: Beosystem integrating networkplayer project #73081
    kknyc
    SILVER Member
    wow, love this project, and hope to add streaming to my 5500 system. Subbed for inspiration👍
    in reply to: BEOGRAM 5500 stutters and bounces on return [video] #72927
    kknyc
    SILVER Member
    HI Martin, Thanks so much for the tip, I’ll try that today.
    I had to re-read it a few times to ‘visualize it’, but now that I think about it there was a thin black plastic ‘cable harness clip’ under there that was dried out and broken—I figured no worries since there was still that ‘black screen’ holding the cables down out of the way of travel. I try a dab of hot glue (in hopes it could be removed if needed)
    Please let me know if Ive misunderstood your suggestion,
    Thanks K
    PS—open to any all glue/adhesive suggestions.
    And does anyone have any suggestions for BEOs dried out plastic parts? Is there a way to revive them (ie 303 spray?) or maybe I should just 3d print new ones? (its just chore for each custom one-off part)
    in reply to: BEOGRAM 5500 stutters and bounces on return [video] #72664
    kknyc
    SILVER Member
    hi, thanks for the suggestion. (I never disassembled the gears just replaced belts). I followed the SM 5.1 to set the gear, then attached the wire guide.
    Is there more to the procedure? —Hmm, I feel like Im missing something
    in reply to: BEOGRAM 5500 stutters and bounces on return [video] #72616
    kknyc
    SILVER Member
    kknyc
    SILVER Member
    wow this is wonderful, great work! —Wish there was a option for the 5500’s MMC cartridges 😉
    in reply to: BeoCord 5500 – Shutting off #72254
    kknyc
    SILVER Member
    How are the Pinch rollers replaced? I got a set of pinch rollers (DSP) for my 5500 Type I, but I’m unsure how to replace them.
    Well, once I had the courage to remove the spring washers on all the spindles everything went smoothly: the rollers were a simple ‘slide pin/insert new wheel’ and all the moving parts/spindles/slides got cleaned and lubricated.
    I still have the low level/muddy sound which may need to go to a tech with the tools needed to make height and azimuth adjustments.  Can any one recommend a tech in NYC area?
    in reply to: Beocord 8000 problems after idler Replacement #72249
    kknyc
    SILVER Member
    well I realize the models arent the same .. I was merely suggesting (your) Service Man and a thorough clean might surprise you. (sorry for the long winded explanation- I just completed mine last night- still on a ‘repair high’)
    in reply to: Beocord 8000 problems after idler Replacement #72242
    kknyc
    SILVER Member
    I just had to do similar to my beocord 5500. Lisa at DSP was really helpful pointing out “find if its mechanical first”.
    you can set (the 5500) in ‘service mode’ by holding the [stop] button + pressing [play] (check your service manual for your model). I was then able to test the capstan and reel motor’s voltage (in idle, and playback in both directions) —mine were: Capstan ±12.99v and Reel ±4.56V
    after replacing all belts/rubber and checking voltage. I then disassembled all the spindles and transport slides (not touching the head) to thoroughly clean and lubricate (hah I could’ve started here). My issue was the L reel was so sticky it would skip, play, then bog-repeat.
    <sorry I don’t know the part names here…>
    if you can also clean the ‘brake’ and ‘the grooved wheel’  (by the [Turn] motor), along with the transport ‘sled’ (containing the transport head/pin rollers assembly) thing may go in your favor.
    in reply to: BeoCord 5500 – Shutting off #72224
    kknyc
    SILVER Member
    I just got done cleaning the transport module—lots of stick greasy to be cleaned out. Both sides now play and FF RW works but there remains two issues.  I hope @Dillen or @Grgur Pauker may have some suggestions…
    1. How are the Pinch rollers replaced? I got a set of pinch rollers (DSP) for my 5500 Type I, but I’m unsure how to replace them.
    2. After getting Play and FF and RW working, the output vol is low and muffled. How could I correct this? (I was careful not to touch any settings of the play head, all components look fine/nothing burnt or darkened).
    Thanks for any links, info, tips 👍
    kknyc
    SILVER Member
    thank you for this post! Im going to check this as new belts didnt solve my issue
    in reply to: BeoCord 5500 – Shutting off #71829
    kknyc
    SILVER Member
    My Beocord 5500 is experiencing a similar symptom, new belts and feet from DSP (surprisingly straight forward replacement). I wish I got the roller wheels, I had to reorder
    Unfortunately, tape will play side 1 but…
    • side 2 volume is muddy and lower
    • press [turn] side 2 plays for about 1-3sec. STOP ->Standby
    • FF or REW – LEDs show movement, but no tape spin, about 5sec. STOP ->Standby
    Also noticed the head travel seems ‘sticky’ doesnt “slide” easily. (I going to go thru the whole Transport area: capstans, head, wheels, with a Qtip and some IPA )
    Any suggestions for essentials lubricant and lubrication points? (if any)
    in reply to: Home Automation #71558
    kknyc
    SILVER Member
    RE: BEOsystem 5500 to Smart speakers
    HI BEOWorld,
    I just inherited a BEOsystem 5500 with two enormous JBL cabinets. But Im currently setup with smart speakers in my apt . Is there a Bluetooth “Transmitter” for sending the BEO audio around the house to smart speakers? For better or worse, Im locked into the Apple ecosystem and would hope to find a DIY or compatible product in 2025
    (Im still unsure if I’d utilize the Speaker 2din ports or some other BEOMaster connection to a ‘transmitter’ unit)
    Thanks for any insights!
    in reply to: BEOTOOTH 5500 : A Datalink Bluetooth Receiver #71557
    kknyc
    SILVER Member
    HI BEOWOrld,
    I love the BEOtooth development. Bravo!
    I just inherited a BEOsystem 5500 with two enormous JBL cabinets. Im currently setup with smart speakers in my apt . IS there a similar project for a Bluetooth “Transmitter” for sending the BEO audio around the house to smart speakers?
    Im excited to get a BEOTooth, and any insights on how I could bring this vintage classic into my modern listening home. (Im still unsure if I’d utilize the Speaker 2din ports or some other connection to a ‘transmitter’ unit)
