Hi tabloka 🙂
Old thread here, but still relevant – if you ask me 🙂
I’m currently sitting with a 7-55″ mk1, which has a half black screen, meaning that a little more than the right side of the screen is completely black. But if I take a powerful LED flashlight and illuminate the panel from the back, I can see there is an image on the entire screen, which tells me that it is either the LED driver, or the individual LED strips inside the Samsung panel.
How did your project go, did you manage to change or fix your LED strips 🙂
Best regards
Jesper G, from Denmark
