Donby
Forum Replies Created
  • in reply to: Beosound 1 faulty CD player #74216
    Donby
    An amazing comprehensive description of how to replace the laser section. Well done Guy
    I found this one, as a friend of mine came with a Beosound 1 with a faulty CD player.
    Why come to me? Well actually I participated in the development of the first compact disc player (CD50 – AIWA OEM inside)  from Bang & Olufsen in the early eighties.
    Fun fact; The Compact Disc Player was introduced in May 1983 coordinated between Philips and Sony.
    Meanwhile I left B&O 40 years ago.
    Question regarding the Beosound;
    As I have not dismantled the unit yet, – still missing a long narrow 20 torx.
    I observe that it can load a CD, but the disc does not spin up. In which sequence does it continue? Does the laser light up to focus on the disc before/simultaniously with the disc rotation start up? No light – no detection of disc and consequently no spin up?
    Or otherwise?
    When I get access, will I be able to see a glimse of red light from the laser, if it works?
    All this before I order a new unit.
    in reply to: Beomaster 6500 & 7000 improvement of pre-amp circuit #72509
    Donby
    Thank you very much Filip.
    I was almost sure about that, but just  – ‘livrem og seler’😊
    I might replace the trimpots after alignment. Out – find how many Ohms, and probably make two fixed resistors i parallel do the same. In a Beomaster 9000 I have seen a similar trimpotentiometer perform erratic after af few decades, resulting in a pretty hot output stage.
    in reply to: Beomaster 6500 & 7000 improvement of pre-amp circuit #72421
    Donby
    Hi Filip
    I saw that you aligned idle current between 2TP200 – 2TP201  for 11 mV  , and similar for the other channel.
    I suppose that is across both emitter resistors 0,22ohm?
    Cannot find these TP stipulated on diagram or print.
