Hakan kutluk
Forum Replies Created
  • in reply to: Beosound Ouverture CD not working #65169
    Hakan kutluk
    Thank you friend,
    I have bought the caps and will change them and will see how it goes.
    in reply to: Beosound Ouverture CD not working #64930
    Hakan kutluk
    Hallo friend
    I have exactly the same problem. I have changed the optical laser, nothing has changed, this time test code shows the “7” wich means data transfer problems.
    CD spins but doesnt play. Next thing I’m going to do is to recap but I’m not sure if it’s gonna work.
    Did you have any success in the mean time?
