Forum Replies Created
gordon mobbs
BRONZE MemberMine was stuck in standby but on operating any function it ran for 6 seconds then went back to standby. I removed the plastic cover from the relay and cleaned the contacts, I also checked the no load voltage per the post and it solved the problem. Not sure if mine displayed P since some of my led don’t function on the display. Hope this helps. Gordon
Favourite Product: Beocenter 7700
Signature: GLMobbs
gordon mobbs
BRONZE MemberHi Ray
Read post #45513 from April 23 I think it would be a good starting point (sorted mine out)
Gordon 6
Signature: GLMobbs
gordon mobbs
BRONZE MemberHi
Update, managed to find a source for the glass encapsulated microswitch which sits in the switch and is actuated by the magnet on the end of the arm once the record is placed on the turntable, now fitted and working.
Gordon
Signature: GLMobbs
gordon mobbs
BRONZE MemberHi Max
Have you tried connecting the speakers direct to the board inside the unit or tried plugging headphones in ?
Gordon
Signature: GLMobbs
gordon mobbs
BRONZE MemberHi Fabienne
Use the tape 2 rca inputs (marked play) on the back and the TP2 setting.
Gordon
Signature: GLMobbs
gordon mobbs
BRONZE MemberHi
Stop the search, I managed to buy a Beocenter 7000 for spares which had the missing pinch roller.
So I now have a fully functioning Beocenter 7700 which I love, great machine.
Gordon
Signature: GLMobbs
gordon mobbs
BRONZE MemberHi Edward I’m pretty sure I’ve seen one on ebay UK recently Gordon
Signature: GLMobbs
gordon mobbs
BRONZE MemberThanks Martin
Signature: GLMobbs
gordon mobbs
BRONZE MemberHi Did you manage to find a source for the cap kit I have recently acquired a 7700 and am interested in obtaining a cap kit also.
Signature: GLMobbs
