gerry@whatbigbrandsknow.com
Forum Replies Created
  • in reply to: Connect Beomaster 7000 to SONOS #38978
    Thank you!
    You guys are amazing.
    I was just scrolling through your site to find the right cable and was going to send you a message.
    You made it easy for me!
    I’ll order this week.
    Thanks!!
    Gerry
    in reply to: Connect Beomaster 7000 to SONOS #38976
    Awesome. SO helpful. Thank you!
    I did try the line in/out and it unfolded exactly as you said.
    I’m sure I did buy the wrong cable.
    This is the one I bought:
    CablesOnline 6ft 7-Pin Din Male to 2-RCA Male Professional Premium Audio Cable, Black for Bang & Olufsen, Naim, Quad.Stereo Systems (BO-2706K) https://a.co/d/ctESyOs
    thanks!!
