espresso_fanatic
Forum Replies Created
  • espresso_fanatic
    I recently redid the entire board and found some possibly helpful notes:
    – Check C6, 22 uf. When this capacitor gets drained, it seems to switch the speaker into standby mode. This might be bad given its age.
    – IC1 could have gone bad but I suspect the capacitor more than IC1. Desoldering SMD components is quite trick as well.
    espresso_fanatic
    I wish I had a solution here. I have a pair of BeoLab 8000’s as well and one of them exhibits the same issue. It toggles very quickly and has some high frequency noise like you mentioned. I am in the process of repairing the amplifier in hope of finding where the noise is coming from.
